1
Scrip for saving as (jpeg or png) and incremental sequence name
Jun 12, 2017 Jun 12, 2017
Scenario:
I'm trying to make a time lapse video.
I have a finished (only one file, so no batching) drawing/painting file with many layers. I made all the layers invisible. Then, I started at my background layers and enabled the visibility of a particular layer, changed the opacity of that one layer to, lets say 25%, and saved the image as a jpeg file named "1" (however, png would be better now that I think about it). Then, I went back to the same layer, changed the opacity to 50% and saved a jpeg file as "2"........ I made it to 250 images and I cannot afford to keep going this way.
Is there a script that could save the images and add a sequential name as in the example, after I have manually modified the opacity of the layer?
I found this unique name command but is either not doing it or is saving the images in some random place.
function CreateUniqueFileName( inFolder, inFileName, inExtension ) {
  inFileName = inFileName.replace(/[:\/\\*\?\"\<\>\|]/g, "_");  // '/\:*?"<>|' -> '_'
  var uniqueFileName = inFolder + inFileName + inExtension;
  var fileNumber = 1;
  while ( File( uniqueFileName ).exists ) {
  uniqueFileName = inFolder + inFileName + "_" + fileNumber + inExtension;
  fileNumber++;
  return uniqueFileName;
I also found this code, which works but the image gets overwritten every time.
var doc = app.activeDocument;
var Path = doc.path;
var Name = doc.name.replace(/\.[^\.]+$/, '');
var Suffix = "-Copy";
var saveFile = File(Path + "/" + Name + Suffix + ".jpg");
SaveJPEG(saveFile, 8);
function SaveJPEG(saveFile, jpegQuality){
jpgSaveOptions = new JPEGSaveOptions();
jpgSaveOptions.embedColorProfile = true;
jpgSaveOptions.formatOptions = FormatOptions.STANDARDBASELINE;
jpgSaveOptions.matte = MatteType.NONE;
jpgSaveOptions.quality = jpegQuality;
activeDocument.saveAs(saveFile, jpgSaveOptions, true,Extension.LOWERCASE);
I wish there was something easy like (see red words):
var Suffix = "i";
var i=1;
var saveFile = File(Path + "/" + Name + (Suffix+1) + ".jpg");
I would appreciate any help. Saving: choosing the quality and renaming is taking too long. I like having the control over the opacity but I want to make the saving process faster and only focus on the opacity/transitions.
Actions and scripting
716
Adobe
Guide ,
Jun 13, 2017 Jun 13, 2017
For batch processing that can use sequential naming you could use Picture Processor, it can be downloaded from
GitHub - Paul-Riggott/PS-Scripts: Photoshop Scripts
This is an amazing tool that I will definitely use when processing many pictures, however, and as stated in my "Scenario", I only have one file that I want to save (hopefully by pressing one button)  over and over again, after a small modification.
I'm trying to change opacity of one layer, and save. Next layer, change opacity, save. And I want to do this until my drawing is completed and I want to keep all the files since the modification to the first layer.
I DO NOT NEED A BATCH PROCESSING TOOL - I just need to save a file multiple times, after small adjustments and keep each saved file with a different name (so that it does not overwrites it).
Here is a sample of what I am working on: Brain Damage Lapse - YouTube
