Hy there, i need some help please. I downloaded the A.I. a few days ago (trial version). The reason for that is that i started a free course about Urban Graphican. I past the first course and now i am on the 2nd. Problem is i'm stuck at the beggining of the course because the select tool doesn't work. i tried everithing but nothing.
As you can see in the first image i tried to select the red line from the building and in the second picture in the left upper-corner it says "No Selection". Can anyone help me.
Its a little bit difficult to understand tha situation.
What I can suggest.
Please open Appearance panel. Appearance panes shows the targeted object style. Try to select the objects with any Selection tool.
In the layer panel you can see the "appearance balls" on the each layers. that show the targeted object. If you will see double circles that means that you now select the object. Try to select the object on that layer by clicking on "appearance balls" .
Also that 'appearance balls" icon design looks like appearance panel icon.
The layer the art is in is probably locked.
No possibility to select any object that is on locked layer. Workaround is unlocking layer.
