Hello all,
Is it possible to change exclamation mark '!' from horizontal to vertical by scripting?
Not only for '!', but also for '!!', '!!!', '?', '!?' etc.
I tried to record it by Script Listener Plug-in, but the AM code is way too long (around 900 lines) that I can not modify the code to fit other cases.
Any help would be greatly appreciated!
Other cases
Yes, this is possible with AM code.
You can read text layer descriptor. Then modify this object and apply modified descriptor on text layer.
Use: GitHub - JavierAroche/descriptor-info: JSX module to recursively get all the properties in an Action... for reading descriptor and better understanding. You will need to create new "textStyleRange" (or paragraph style range) and this range will have different direction property.
Thanks, Bereza, I will try to read the text layer descriptor and see if I can figure it out.
