I get the message "CEPHtmlEngine quit unexpectedly" every time I quit Indesign. I already opened Indesign holding the ALT-Key so clear the preferences. This worked for just one time. After the next time closing the application the message comes again.
I already uninstalled Indesign, cleared all caches, even font caches, restarted and reinstalled Indesign, but the condition stayed the same.
Has anyone an idea to solve this?
Cheers,
Tilman
Holding down the Alt key wouldn't restore your InDesign preferences. Read this article about the proper keyboard method and the method of removing files to restore preferences
Trash, Replace, Reset, or Restore the application Preferences
Hi Steve, thanks I already did the trick holding ALT when opening the application. Made it for me once but then the error returned.
Hi Cari, i don't use any plugin and my OS is macOS 10.12.5 with CC2017 (Indesign 12.0).
Cheers,
Tilman
Do you have any third party add-ons (extensions/plug-ins) installed in InDesign?
Also are you running InDesign CC (2017)? or another version of InDesign?
Which Operating System are you using (e.g. Windows 10?)
Bumping this again. Problem happens on my CC2018, but it's been happening for years - and it's on my MacOS 10.12.6 machine. No info in activity monitor (tried High CPU usage due to CEPHtmlEngine )
It doesn't show much CPU usage at all, so it didn't work for me. No notes in Console, either.
Happens with InDesign, Illustrator and others.
Same here. Been happening for a long time. I've tried replacing preferences, etc. I even just tried the High CPU usage due to CEPHtmlEngine "fix," but it doesn't fix anything for me (realizing that this fix is from two years ago -- I noticed that there have been some changes in directory structure/location of some of the folders referenced here since then, but I was able to locate them).
I even recently uninstalled one of the CC apps in question (Illustrator, in my case, since that's where I notice it most -- I rarely quit InDesign, because that's the program I use 95% of the time, so I just always leave it up and running), rebooted my Mac, and reinstalled the app. Didn't change a thing -- still have the crashing CEPHtmlEngine.
Granted, this annoyance is just that -- annoying -- and doesn't seem to be causing any other issues. No problems using the actual CC apps, themselves, from what I can tell.
Oh, well. Someday, maybe this will be fixed. Perhaps I'll post a bug report on my end (again...? can't remember if I did this already in 2016 or not).
FWIW:
MacBook Pro (15-inch, late 2011)
2.5 GHz Intel Core i7
8 GB RAM
AMD Radeon HD 6770M (1 GB VRAM)
Crucial 1 TB SSD (717.76 GB available)
OS X Sierra (10.13.4)
CC 2018 (all apps up-to-date as of this posting)
I've reported this so many times, my fingers could fall off.
As you said, it doesn't seem to affect anything significant, but it IS annoying. In looking at Console when it happened, I seemed to see that it's somehow about the whole connection to the CC cloud thing, but that's as far as I've gotten. I've just learned to live with it, and be annoyed.
This happens to me EVERY TIME I quit Indesign CC 2018 - mac OS 10.12.6 - latest builds of InDesign etc.
Really damn annoying.
The other links to download and replace some files doesn't work!
CAN WE PLEASE FIX THIS
