I'm trying to create a document that is being exported to HTML. When I am doing this the program is taking text boxes within the main page text box and they are being rasterized which is no good for being transferred into a mobile app.
Please can anyone shed any light on this?
Many thanks in advance.
Regards
Daniel
Use custom instead of inline or above line. That will give you an anchored text frame instead of an inline text frame.
What version of InDesign? What operating system? Are these anchored frames? What are the exact HTML export settings?
Hi Bob,
Its the latest version of InDesign so CC 2017 Version 12.1.0.56 x64 Build.
Operating on Windows 10.
These boxes are anchored to the text above and I have attached images of the settings being used.
Daniel
You didn't say if you created the ID file yourself, but click on a troublesome frame and check the Object Export Options (Object menu) > EPUB and HTML and make sure it says Default, not Rasterise.
Default means use the settings that Daniel displayed in the Export box.
Check to see if an Object Style has been set. If so, you can redefine it and catch them all. Otherwise you fix them one at a time.
I've checked the settings and they are set to default and so is the option in the Object Style that has been used for all of these type of text boxes.
I'm trying to duplicate that here and I can't. Does this happen with other files as well?
I'm getting the message 'Inline objects like text frames, groups etc. have been rasterized.'
Not sure if this helps find a fix for this? Is it a positioning issue?
I have seen it in other documents I've received from the same creator of the document but only a few times out of a couple of hundred.
I think this to do with the way the objects have been anchored as when I move one of the boxes and it changes to the custom settings it shows correctly in the HTML file.
Would the below setting cause this?
I'm going to have to inform the creator of this going forward and amend these individually.
Thanks for the help in figuring this out, it's much appreciated.
Regards
Daniel
While you are informing him, suggest that he/she use Object Styles for these frames so this setting can be changed quickly for print and for html. (If needed, all other attributes can be unchecked.) When the style is redefined, all frames that use it will update. The creator might want Inline for Print and you might want Above Line or Custom for HTML.
Neither of you wants to change it one frame at a time.
Hello, you should test with the plug in IN5, in the trial version to see if it's the same result
