Just purchased Adobe Export PDF. When converted to MSWord, there are no images. How can I get the images from the PDF?
Hi eyesoflight,
Try once to repair the application. Launch the application and go to Help menu > Repair installation.
Also, you can export PDF online here: https://cloud.acrobat.com/exportpdf
Check if you can get the images or not.
As you said that the there is no images, do you mean only images do not convert when you export PDF?
Is it an issue with a particular file? Have you tried to replicate the issue with other PDFs?
Can you share the file so we can check it on our end?
You may refer the steps provided here to share the file How to share a document
Let us know if you need any help.
Meenakshi
Hi, Thank you for your prompt response to my question. Here is a link to the document. I am trying to sell this house, but I don't want to give the potential buyers the whole document - only certain parts - like the images. Any way I can get those out of the pdf with Adobe Convert PDF?
Hi EyesofLight,
It is not possible to export certain part of the file.
Export PDF converts the whole PDF to another format file.
If you just want to send the images, you have to create a new file with images.
Please let us know if you have any questions.
Meenakshi
Can you convert the file to MSWord and still see the images in the Word doc?
The file that you have shared above is an MS Word file.
Please share the PDF file so we can check it at our end.
Meenakshi
How can I attach the pdf to a reply on this forum?
Please refer the steps provided here to share the PDF: How to share a document
Also, share the screenshot of the both the PDF and the Word file that you get after converting the PDF.
To share the screenshot use the insert image icon shown below:
Then click on Choose File and then browse the location where you have saved the image file of the screenshot.
Select the file and click on Open > Insert Image.
Meenakshi
