Hello,
I was experimenting with compression of psd and psb files but it seems not to work (Photoshop CC2017.1.1).
My aim is to monitor performances while opening/saving a 2.9GB psb on SSD and HDD.
Unfortunately disabling compression seems not to work, indeed the file saved without compression is the exact same size of the one saved with compression (already tried not maximizing compatibility).
So far my findings with compression on are as expected, the two drives have nearly the same timing:
Compression enabled | 1xSSD | 1xHDD | 2xSSD | 2xHDD | 3xSSD | 3xHDD |
open (s) | 10.2 | 11.8 | 10.6 | 10.4 | 10.2 | 10.4 |
save (s) | 14.1 | 17.3 | 13.8 | 14.3 | 13.8 | 14.2 |
is there a way to effectively disable the compression?
I tried checking disable and reopen Photoshop but still not working.
Message was edited by: Alberto Bua - added PS version.
I wonder if this is something in the files. I also tried this and got identical results to the original poster i.e. no change in file size. That wasin both CC2017 and CS6. I will try variations on the image mode and content later this evening.
Dave
Why not try Tiff?
Because I would like the setting to works
Of course - I meant only for your testing.
Just got back to my workstation and gave compressed/uncompressed PSD a try. The compressed PSD took longer to save, so I figured it had worked. Sure enough, it had - compressed: 565,220K; uncompressed: 960,549K. See here:
So now I must ask for further details on your testing process. Did you simply change the setting under Edit > Preferences > File Handling and save...or did you change settings, restart PS, rebuild file, save? The latter is what you should do.
I am also running PS CC 2017.1.1 (4/25/17 build) There is an update over in the CC app I've not installed yet. I'll update and try again to be sure.
That's so strange. I'm not able to make it works.
Tried everything you said, i.e.: change the setting, restart PS, rebuild the file, save the file.
The resulting file size is exactly the same hence opening/saving have the same timings.
I've the same build as yours: Adobe Photoshop Version: 2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967 x64
Hmm, that is very interesting. By the way, are you on Mac or Win? You could try a preference reset.
Win: Press and hold Ctrl+Alt+Shift immediately after initiating Photoshop's startup. A box will appear asking if you want to continue with the reset, select "yes." If you don't see this, you weren't fast enough...Try again.
Mac: Press and hold Cmd+Opt+Shift then start Photoshop. A box will appear, asking if you want to continue with the reset, select "yes."
Thank you for remembering me to reset the preferences. Unfortunately no luck.
I've also tried updating to the latest version (that stayed exactly the same --> Adobe Photoshop Version: 2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967 x64) but to no avail.
I create the PSB (1.5GB) in this way:
- create a new blank 60.000x60.000 px image;
- duplicate the background 5 times;
- save.
Dave
That could be. I used five layers with a Hard Light blend mode and three adjustment layers. Also, 16 bit and ProPhoto RGB. Both files were 100% identical except compression
Was finally able to have it to work.
Opened 5 5DSr raws as Layers and put 4 of them in hardlight and saved with compression disabled = 2GB (6 seconds).
Changed the setting to enable compression and resaved (not event needed to restart PS) = 1.3GB (82,4 seconds).
Finally
Hi
Well I was still puzzled so I saved with a plain white single layer file 1500x1000 pixels which uncompressed in 16 bit should take 9MB and in 8 bit 4.5MB as plain "Raw" RGB data. No matter how I set the "Disable file compression" in preferences the filesize on disk was a very compressed 94kB for the 8 bit and 170kB for the 16 bit - so some compression was obviously going on.
I downloaded the PSD spec
Adobe Photoshop File Formats Specification
There are various parts of the file which can be compressed by different methods - the image data section is at the end.
So I created some plain white single layer files of various pixel dimensions and opened them in Visual Studio with a binary editor reading them against that spec. This confirmed that apart from tiny pixel dimensions e.g. a 5x5 image , image compression does get applied to the image data regardless of the disable compression setting.
That preference setting is obviously impacting the level of compression in various parts of the file but it is not a simple "no compression" vs "some compression" switch.
Dave
Wish Chris Cox still dropped in once in a while
Hi Benjamin,
I get the impression that Chris Cox may not be at Adobe now. If you look at his LinkedIn profile it states Senior Computer Scientist, Adobe Systems Incorporated Sep1996-June 2016. That is around the time we stopped seeing posts from him.
I hope he is OK as his knowledge and insight was superb
Dave
Dang, that looks like bad news indeed. (Edit: Well, not exactly »news« in every sense of the word …)
His knowledge was a valuable contribution to these Fora and while he may not have exactly »dumbed down« his replies as much as many a poster might have liked his patience and restraint seemed commendable to me.
Like I say - got to be careful, I've seen no confirmation that he has moved on, but that profile does seem to suggest that. Also his forum staff profile is shown as "Deactivated"
I agree with you, Chris' posts were invaluable.
Dave
I was impressed with how often he returned to try and explain issues (or Adobe’s stance on them) to people who apparently had problems processing the information he provided.
And on the other Adobe Fora I occasionally visited (Illustrator and Indesign mainly) I got the impression that his involvement with users was not the norm among Adobe staff of a comparable position at other product teams.
Really interesting!
I'm pretty new to this stuff, I think I got the image data section start address but how can I understand if it is compressed or not?
In the example below there are 2 "uncompressed" PSB (in the sense that disable compression was checked):
- the left one is a 2x2 px 1 layer (background layer only) all white;
- the right one is a 10x10 px 1 layer (background layer only) all white.
You can see the compression in two ways.
The image data section immediately follows the byte with value 32 that you highlighted, and easy to work out on the 2x2 file.
The first two bytes are 00 00 which , according to the spec. I linked previously, indicates Raw data i.e. no compression. This is confirmed in the following data which is 3 blocks of 4 bytes all set to FF. That corresponds to 4 pixels with R G and B all set to FF.
If you then take a look at the second file you can see that those first bytes are now set to 00 01 which, according to the spec, indicates RLE compression. The image data format is now very different and does not follow a straightforward R G and B value for every pixel. The section is also shorter than uncompressed which would take 300 bytes if in Raw format.
Dave
Thank you! Got it.
