How to check if a flow contains a particular paragraph style?
Jun 16, 2017 Jun 16, 2017
The script iterates through a doc and works on changing conditional tags in it but it does not factor in whether the paragraph style is "Anchor" i.e. whether it contains an Anchored Frame or not. How can I use the flow object to check if the paragraph style is "Anchor" or if the paragraph contains an Anchored Frame or not?
Working code is
var flow = active.FirstFlowInDoc
        while(flow.ObjectValid())
            // need an if condition here before calling the changeCondTagInPgf function
                 changeCondTagInPgf(flow,active)
            flow = flow.NextFlowInDoc
The script should only call the ChangeCondTagInFlow() function if the paragraph style is "Anchor" or if it is/contains an Anchored Frame.
Scripting
353
Community Expert , Jun 16, 2017 Jun 16, 2017
This post has the test to see if the paragraph contains an anchored frame:
How to check if a paragraph is/contains an anchored frame or not? if it is/does, apply/remove conditional tags on it?
You should be looping through paragraphs, not flows. To test for the Anchor paragraph format, you can use this:
if (pgf.Name === "Anchor") {
    // Do something here.
You can combine this with the function in the other post:
if ((pgf.Name === "Anchor") || (hasAnchoredFrame (pgf)) {
How to check if a paragraph is/contains an anchored frame or not? if it is/does, apply/remove condit...
Can I access paragraphs from within flows?
pgf = flow.FirstTextFrameInFlow.FirstPgf;
Jun 21, 2017 Jun 21, 2017
Hi Rick, The script appears to work correctly now, but I am receiving the following error in the FrameMaker console: Graphic file can not be replaced with Text file. I have used your frameautomation tutorial as a reference to change conditional tag applied on paragraph. Can you please explain what am I missing?
