After exporting a photo, I'm noticing a major difference in colors between the photo I've exported (now being viewed outside of Lightroom) and the photo as it looked in Lightroom. I'm not sure if this is a color space issue or a calibration issue or something else entirely. My camera (Nikon D750) is set to sRGB, as are the exports. Below is a screen shot of the exported photo (on left) and as it shows in the Lightroom development panel (on right). What is causing this, and how can I fix it?
You seem to be using the Windows Photos App, which is not color managed, and will not display correct colors.
Lightroom is color managed, and will display correct colors, as long as the monitor profile is correct.
This difference in color is more pronounced if you have wide gamut monitor, in which case you have to use only color managed applications to view your work.
Bridge and Irfanview a
...Copy link to clipboard
It could be that the application you are using to view the photo outside of Lightroom is not color managed.
What application is it?
Also, is your monitor calibrated?
Bridge and Irfanview are both free and color managed (you have to enable color management under Settings in Irfanview).
On Windows 10, the Windows Photo Viewer is apparently still color managed, but it's hidden somewhere. Do a search for it.
A paid option is the latest version of ACDSee (20).
The color space you set in the camera only affects jpgs (and the jpg embedded in the raw files), if you shoot raw, it doesn't matter which color space you choose.
I had a similar issue even with calibrated monitors, and tried even using monitors of friends but the same thing was happening. A color and contrast shift. Meltjabb, did you end up getting matching colors?
As already said, Windows 10 and Wondows Photo are not color managed. As a consequence the colors seen in Windows photo are not correct.
However, the old Win7 Photo Viewer is color managed and it is still there in Windows 10, although hidden. You can activate it as decibed HERE
The problem with sending photo to other is that you have no garantee they will see your image the way you edited it, and there is nothing you can do about that. It all depends if they are using a calibrated monitor and a color managed application.
Please check if you may have some sort of color management in the app you're using. I see differences too if I watch on "preview", the mac app versus anything else...
