WHY? Obviously it's not scanned image.
Here is test.pdf: http://waldens.github.io/test.pdf
It's just one page for test and copyright free, feel free to download and test in you Android. Thanks
Hi lidesany,
I tried to replicate the issue at my end. I am able to highlight the text in PDF that you have shared.
When you open the PDF in an Android application, tap on the PDF and you will see four options provided at the bottom.
Tap on the second icon that is comment icon and then select the highlight tool.
Now try to highlight the PDF and check if it works or not.
You may also refer the steps provided here: Acrobat Reader Help for Android: Annotating Pages
Let us know if the issue still persists.
Meenakshi
You're right! It indeed can highlight text.
My mistake, what I really ask is, "Same PDF, Acrobat Windows CAN select text, Acrobat Android CANNOT select"
When we press the screen long time on a text, Acrobat should select the text and pop up a menu, like GIF1 shows in the below.
But in GIF2, why can't I select text by this way? can how can I select and copy text in text.pdf?
Four days from the last reply...Will this problem become an pending case that cannot be solved?
Any help or suggestion?
