I cropped my photos and changed the ratio to 1 x 1. In the Book module I selected 7" x 7" , one page layout, full page. In the development module I set the format to 1 x 1 and cropped the photo exactly the way I want to see them in the book. When I drag photos to the page, they do not fill the entire page. I do not want to zoom the photo after dragging it on to the book page. Why is a 1 x 1 format not filling the 7" x 7" page?
After sleeping on this question, I solved it. First I went to the book module and cleared the book. Then I reselected the 7" x 7" format and set the default page layout to 1 and full bleed. I could not find where to set zoom to full but I guess that was default. When I dragged the photos into the book they filled the page and looked like the cropped images.
What was used to take the picture? What are the pixel dimensions of the cropped image?
Taken with Lumix GX85. Cropped image is 2292 x 2292
Is the Cell Padding set to 0 pt? If you can, please post a screenshot of one of the affected pages.
A J
The cell padding is 0 pixels
And- Which page template are you using?
The one on the left, or on the right of this screen-clip?
The one on the right.
You have to click on the image to see the borders. It is not showing up on this reply window.
We can work with this image. The white canvas on the sides can be cropped (again) in Lightroom.
Then drag this image back into your book.
If your full image does include a white border (and the screen-clip image is not 1:1) then you are seeing the photo's white border on the book page, not the white page background. Set the page background to black and see what the effect is with the photo 'as is'.
You will need to crop the image to 'remove the white border as indicated by SERVITOR in the above post.
Otherwise it seems you have everything correct.
