My computer crashed last week and I had to reinstall Lightroom 5. I had no issues with it prior to my computer issue, but now with all NEF files, I have the message "preview unavailable for this file". I can see all of the NEF files on my computer, and on Photoshop with no issues. I thought that when I had originally purchased the Lightroom 5 software, that there was a setting in Lightroom that I needed to change in order for the NEF files to show previews just like a JPG file would. Is there a setting in Lightroom or software that I need to download in order for Lightroom 5 to recognize these files? I am definitely an amateur when it comes to any ediiting software, as I just use it as a hobby. Any help would be greatly appreciated!
The update to 5.7.1 should solve your problem.
It depends on what camera you are using, but you should at least update (it's free) to version 5.7.1 to see if that solves the problem.
Nikon D5300 is what I have.
Sent from my Verizon, Samsung Galaxy smartphone
Thank you! Will see if this works!
That worked! Thank you so much!!
Cameras supported by Camera Raw
The table at the link above shows that your camera has been supported since Lightroom 5.3.
When you re-installed Lightroom 5, it probably put you back to version 5.0. As dj_paige says, update to 5.7.1 and you will be able to open your Raw files.
Thanks! Will see if this resolves the issue!
