Im trying to figure out where I am failing on my requirements to use photoshop.
Model Name: MacBook Pro
Model Identifier: MacBookPro9,2
Processor Name: Intel Core i5
Processor Speed: 2.5 GHz
Number of Processors: 1
Total Number of Cores: 2
L2 Cache (per Core): 256 KB
L3 Cache: 3 MB
Memory: 4 GB
Boot ROM Version: MBP91.00D3.B0C
SMC Version (system): 2.2f44
Intel HD Graphics 4000:
Chipset Model: Intel HD Graphics 4000
Displays:
Color LCD:
Display Type: LCD
Resolution: 1280 x 800
Pixel Depth: 32-Bit Color (ARGB8888)
Main Display: Yes
Mirror: Off
Online: Yes
Revision ID: 0x0009
Displays:
Color LCD:
Display Ty
Mirror: Off
Online: Yes
Built-In: Yes
What version of OSX? I have the same model MBP and no problems running CC 2017.
OSX 10.10 is the minimum.
10.9.5.
So you're not failing on hardware. It's on the operating system.
Every time I go to update OS it says it's installed. haha I'm not sure techy so I'm a little lost.
OS X 10.9.5 is probably looking for an update to OS X 10.9.x. You're on the latest update for 10.9.x so there's no update.
However, you can upgrade to newer versions of OS X. Photoshop requires 10.10+.
You can upgrade for free
I click on the link, and i go to upgrade now but when I do it says its installed already.
So two options:
Upgrade to 10.12.5 which is free, or use CC 2015.5 which will run on 10.9
I have one incompatible update and its iPhoto, is that what's holding it back or something?
What is the exact error message. Can you post a screenshot?
Ah. Look in Applications for an app called Install Sierra or something like that. Bear in mind that you may need to buy all new applications, it's a very big change. Make sure your backups are good, and up to date.
