change CheckBox Appearance
Jun 16, 2017 Jun 16, 2017
     I'm using indesign cs6. I want change the checkBox states of Normal On to Normal Off state using indesign scripting. I'm trying more but i can't find it. Pls guide me.
var mySelect=app.selection[0]
var str=mySelect.states;
for(var i=0;i<str.length;i++)
    if(str.name=="Normal On")
    str.statetype==StateTypes.DOWN_ON,1181970022
Thus, the above code was I'm tried,
The following Image is Require Output
Sangeetha.K
Scripting
1.3K
Community Expert , Jun 18, 2017 Jun 18, 2017
Hi Sangeetha,
from your discription I'm not sure what you mean.
Ask yourself: How would I achieve my goal when using InDesign's user interface.
Can you describe that before we get to the scripting part?
Do you want to change the active state?
Like that:
A checkbox done in the UI like the one you are showing:
Duplicated that checkbox and set the first state of the selection with: active = true
That will only change what you see in the layout.
If you export both checkboxes to PDF Interactive the behaviors
Moving to InDesign Scripting forum
I find out the answer
app.selection[0].activeStateIndex=0
If I change the activeStateIndex vaule means it will move to next level of the "Normal off".
Hi Sangeetha,
I'm not sure, if you read my two posts before…
// checkBox selected:
is the same as:
app.selection[0].states[0].active = true;
Glad it is working for you now.
Would you mark your own answer as "Correct" please.
Uwe
Jun 19, 2017 Jun 19, 2017
hi Laubender,
Sorry, i am not saw your post. I Find only
Steve Werner post.
Guide ,
Really sad to see you gave the correct answer mark to Steve
Hi Laubender,
Actually I am new to this forum. I don't know how to i mark it as its correct. Please can you teach me.
Unmark Steve's post—sorry, Steve ;-)—and mark the other post as correct.
Hope, this helps.
Uwe
Hi Sangeetha,
Like that:
If you export both checkboxes to PDF Interactive the behaviors of both checkboxes will be the same.
Uwe
Why did I states[0] and not states[1] ?
The UI is not reflecting the stacking order of states with scripting.
Stacking order of states of a Check Box with scripting from my German InDesign CS6:
As you can see from the locale independent names of the states and the statetype, on and off are switched.
    0    Normal - Aus    $ID/$$$/StateType/NormalOff    StateTypes.UP_OFF
    1    Normal - Ein    $ID/$$$/StateType/NormalOn    StateTypes.UP_ON
    2    Cursor darüber - Aus    $ID/$$$/StateType/OverOff    StateTypes.ROLLOVER_OFF
    3    Cursor darüber - Ein    $ID/$$$/StateType/OverOn    StateTypes.ROLLOVER_ON
    4    Klicken - Aus    $ID/$$$/StateType/DownOff    StateTypes.DOWN_OFF
    5    Klicken - Ein    $ID/$$$/StateType/DownOn    StateTypes.DOWN_ON
Uwe
Jan 22, 2024 Jan 22, 2024
Hi! I do not have very much experience using scripts. I want to change all the checkboxes in my interactice document from "normal on" to "normal off" at once - otherwise going through and selecting each checkbox individually and changing their default to "normal off" would take waaaaay too much time (it's for a very long workbook).
Is there a way someone could share the code used to run such a script for the latest version of indesign?
