Incrementing textFrame creation inside a function
Jun 15, 2017 Jun 15, 2017
When I run my script it does exactly like I want... It adds a text frame with the "grid location" for the selected items. My only issue is that it isn't incrementing the text frames. I believe line 42 is the issue....because every time it runs my function it resets the xCoor, yCoor, and inc back to zero. Anyone have an idea of how i can make the text frames not stack on top of each other??
#target illustrator
function findGrid() {
var d = activeDocument,
    ps = d.layers['42 Pg Grid Location'].pathItems,
    l = ps.length,
    o = 'ABCDEFGHIJKLMNOPQRST...',
    W, H,
    rows = columns = 1,
    origin = d.rulerOrigin,
    newOrigin = new Array(2),
    t, b, center, gx, gy,
    i = 0;
for (; i < l; i++) {
    if (ps.width == 0) {
        columns++;
        !newOrigin[1] && newOrigin[1] = origin[1] + ps.geometricBounds[3];
        !H && H = ps.height;
    if (ps.height == 0) {
        rows++;
        !newOrigin[0] && newOrigin[0] = origin[0] + ps.geometricBounds[2];
        !W && W = ps.width;
d.rulerOrigin = newOrigin;
W = W / columns;
H = H / rows;
t = app.selection
b = t.geometricBounds;
center = [b[0] + (b[2] - b[0]) / 2, b[1] + (b[3] - b[1]) / 2];
gx = Math.abs(center[0]) / W;
gy = Math.abs(center[1]) / H;
d.rulerOrigin = origin;
//alert('' + o[Math.ceil(gy - 1)] + Math.ceil(gx));
xCoor = 0;
yCoor = 0;
inc = 0;
createGridText = d.textFrames.add();
createGridText.position = [xCoor, yCoor = (inc -= 20)];
createGridText.contents = '' + o[Math.ceil(gy - 1)] + "-" + Math.ceil(gx);
//alert(createGridText.contents);
for (var z = 0; z < selection.length; z++){
findGrid();
Here is what the output looks like....
Here is my desired output....
Any help would be appreciated!!
Scripting
875
Valorous Hero , Jun 15, 2017 Jun 15, 2017
You are never really doing the (inc -= 20) to create an offset from previous item because your inc = 0; is always defined in the function which is repeated in loop. So your inc is always at -20 for all the items. To decrement your inc, define it outside the function - I'd put it right above the loop which calls the function.
Adobe
Change lines 40-42 from this:
inc = 0;
to this:
inc = 20;
createGridText.position = [xCoor, (yCoor -= inc) ];
Jun 16, 2017 Jun 16, 2017
inc = 0;
to this:
inc = 20;
This still keeps everything stacked on top of each other.
Valorous Hero ,
Perfect! Moved inc =0; outside the function just like you recommended and it works perfectly!
Here is the final code...
#target illustrator
    l = ps.length,
    W, H,
    rows = columns = 1,
    i = 0;
        columns++;
        rows++;
        !W && W = ps.width;
W = W / columns;
H = H / rows;
t = app.selection
xCoor = 0;
yCoor = 0;
inc = 0;
findGrid();
Hi wolfeEdition​,
that's strange. Your code does not work.
Did you running the code from ESTK or directly from Illustrator? Is this all - or only a snippet from a larger script?
Pasting the code in ESTK and select few paths which are located at layer named 42 Pg Grid Location and running your snippet gives  the first error in line #26 d.rulerOrigin = newOrigin;   --> Point value expected
After changing line #10 in /*newOrigin = new Array(2),*/ newOrigin = new Array(0,0),
the script works. but all contents of every new text frames is: undefined-NaN
Enthusiast ,
Jun 17, 2017 Jun 17, 2017
Seems relative to this post: Re: textFrame resides in a "grid location"
Jun 19, 2017 Jun 19, 2017
YES! moluapple​ I am building off of that code. I have 2 different accounts.... one is for work and one is for my personal stuff. I accidentally posted this under the wrong profile. Thanks so much for your help on the other post!
I am running the script from ESTK. Sorry I pasted in a working version....this is my final code....
#target illustrator
        l = ps.length,
        W, H,
        rows = columns = 1,
        i = 0;
            columns++;
            rows++;
            !W && W = ps.width;
    W = W / columns;
    H = H / rows;
    t = app.selection;
    xCoor = -50;
    yCoor = 0;
  inc = 0;
  incTwo = 0;
  d = activeDocument
for (var z = 0; z < selection.length; z++) {
    xC = -350;
    yC = 0;
    createComponentText = d.textFrames.add();
    createComponentText.position = [xC, yC = (incTwo -= 20)];
    createComponentText.contents = selection.contents;
    findGrid();
Okay. I see. This snippet required the: Find Text Grid Location.pdf
In other documents the script cannot work.
Is there an easy way to get all of this to happen on a new document instead of the current active document? Meaning it gathers all the information from the current active document and then puts it all on a new document.
Valorous Hero ,
You mean save as a copy, then process?
