Hello all
It has been a few months since I have done work on my site.
I am trying to format text to add links. I have created my text frames within my pages and added the text.
I am trying to use the text tool to select the text, but all it's doing is adding another text frame. Not sure what I'm missing.
Thanks in advance,
Nick
I just figured out the problem. Reason I couldn't access any of the text in any of the pages was because I had locked each one. Of course, once you lock the page, nothing can be changed. Why hadn't I thought of this yesterday working on it?
And yes, I am working on my layout pages, not my Master page.
Thank you for your suggestions regardless.
Nick
• Did you double click into the text box?
• Is a different (perhaps transparent)) element overlapping the text box?
• Did you try to edit text in a newly created textbox after having restarted Muse?
I've never done any transparencies using Muse.
In regards to the newly created textboxes, I never entered any data into them, even after restarting Muse.
Perhaps your first suggestion could be. I will double click the text box and see what happens.
Will keep you updated.
I didn’t refer to "transparency", but to transparent elements. If you place a rectangle for example, it is transparent. And if this is placed over a text frame, you can’t reach the text frame.
Referring to "newly created textboxes": I wanted to make sure, that there is no "hickup" within your document. If something doesn’t work, it is best practice to try this by opening a new document and try there.
I didn't know that about transparent elements.
Might it be best then two delete those two pages and create new ones? Would it still be possible to have them placed in their original locations in my nav bar?
Would I just relink the pages to my nav bar at that point?
Really don’t know, what you are trying to achieve.
Your initial question was about editing text. Is this working now or not?
This should work,
Nick
Thank you for posting your solution here. It will help other users with a similar issue.
Preran
