My keyboard (Microsoft) has a set of "My Favorites" keys that I can use to open folders or files with one touch. If I press one of these keys while Acrobat is in focus, Acrobat will crash and show the "Adobe Acrobat has stopped working" splash screen. I can switch focus to another application before pushing one of these keys to avoid the problem, but it is easy to forget. This is a consistent problem. My workstations runs Windows 10 64-bit and Acrobat X. The hot-key for MS Calculator does not cause this problem.
Message was edited by: Mod to get back in the Queue.
Acrobat X is not officially compatible with Windows 10. One of the areas where this incompatibility is likely to manifest itself is the integration of the application with the OS, like what you've described... If the same issue can be reproduced with Acrobat XI or DC then you could report it to Adobe as a bug, but as such it falls beyond the scope of support.
You posted this in the Lounge, which is a forum for non-technical discussion. I'm moving the post to the Acrobat forum, so that you'll more likely get the help you need.
