Hello,
I am writing to you for assistance.
I have made a site in adobe Muse 2017 CC and wanted to advertise it with google adwards. But unfortunately they have declined my inquiry because of Muse script.
Here is this script: http://musecdn2.businesscatalyst.com/scripts/4.0/jquery-1.8.3.min.js
As far I understand, Muse is trying to reach external jQuerly library, to speed up the page loading. But chrome is blocking it because Muse uses synhronic loading the script or scripts with "document.write()" (here is the link to an article: Intervening against document.write() | Web | Google Developers ).
Because of this, ADwords bots can not correctly scan my site. They see the link to page with error 404, (CDN inquiry was blocked). Google can not promote sites with 404 links.
I have also found out the blocking of such scripts almost on each "Muse site of the day". Does it mean you can not promote/advertise any sites made in Muse??
Link to my site: главная | УАПК
What can I do to fix this?
I would be very thankful if you could reply ASAP.
Could it be that lines 1976 and 1979 should be swapped around so that the backup comes second as per
1974 <!-- JS includes -->
1975 <script type="text/javascript">
1976 window.jQuery || document.write('\x3Cscript src="scripts/jquery-1.8.3.min.js?crc=209076791" type="text/javascript"> x3C/script>');
1977 </script>
1978 <script type="text/javascript">
1979 if (document.location.protocol != 'https:') document.write('\x3Cscript src="http://musecdn2.businesscatalyst.com/scripts/4.0/jquery-1.8.3.min.js
I am checking with the related team members because I haven't heard of a similar issue previously. I will get back to you as soon as i have a response.
Preran
Thank you! Hope to get an answer as soon as possible.
If such issue start to appear on other sites it can be a serious problem for all muse users.
this is the fallback script that should only load when people come to your site with outdated browsers... Google should not be blocking this.
who is hosting this site... I would first assume it is them that is blocking the file but best of luck with it
Strange thing, I am using the last version of Chrome but I see this stuff.
I have version that the site was blocked because it trying to reach this links:
null:1 GET http://ua-pk.com/null 404 (Not Found)
What it can be? And how to get ride of this?
Hi, with an expectation of more technical and expert advice taking help of Dreamweaver support forum.
Ankush
1977 </script>
1979 if (document.location.protocol != 'https:') document.write('\x3Cscript src="http://musecdn2.businesscatalyst.com/scripts/4.0/jquery-1.8.3.min.js" type="text/javascript">\x3C/script>');
1980 </script>
How is this the answer? Can there be an easier explanation?
Please let me know. Thank you!!
Yes. Don't use Muse to build websites. Muse is end of life and no longer being developed.
Adobe Muse EOL announcement - Alternatives to Adobe Muse?
imo there is more going on here than just the default Muse code... who is hosting this site?
p.s, nul is a code term for blank... basic translation = "I don't know what to do here" or "I have no data to work with"
