Can anyone help me understand few issues i am facing while working on publish online option of Indesign.
Moving to InDesign
This FAQ might give you a start:
If that doesn't help, ask us your specific questions.
When I create an Indesign document with animation, interactivity, sound etc and publish it online its work fine in browser but the same file when I convert it into swf and if there is sound too animation stops. But if i remove sound and convert it into swf all the links and animation work.
SWF is an obsolete format so don't use it unless you have a very specific reason for using it. Try FXL ePub instead or the in5 plugin: Ajar Productions: in5 - Home
Thanks Derek
Can you please tell me in detail about in5
The in5 website (link above) gives lots of information.
Ok. Thanks a lot Derek
Hi Derek
I installed the trial version of in5 and it looks good. Will further explore it.
Regarding online published document, one more thing, when I create some online published document it works well on computers but when I try to see this document on mobile phone or ipad etc sound do not work. Any idea why this happens.
Thanks and regards
Hi Mohammad,
unfortunately I have no idea why your sound is not working on an iPad or mobile phone.
What are the technical specs of the phone and the iPad? iOS version? Viewer version?
Could we see into this?
Can you provide a link to your published online project so that we could test it?
Also: I would give In5 a chance.
Maybe there is a difference.
If that would not help I would report a bug for the Publish Online feature.
Together with a link to a sample InDesign package zipped that you could provide with your Dropbox account or a similar service. Use this link to report it:
Uwe
Hi Laubender
Thanks for your reply.
I will provide you the link to my published online project and all the supporting files on weekend.
Thanks and regards
Hi Laubender
I have published online following two documents
With sound
https://indd.adobe.com/view/ae756550-4600-4158-8568-0d2f5f46f4b9
Without sound
https://indd.adobe.com/view/6240c03a-368a-4c2e-8790-6a4dfe694117
These two are same and only difference is one contains sound while the other is without sound.
These are working fine on computers but the only problem is when I visit the link containing sound on cell phone or iPad there is no sound and only animations appear.
Same as when I export this InDesign file containing sound as SWF file all animation stops which appears after sound.
Your help in this regard will be highly appreciated.
I can provide you the working InDesign files if you wants.
Waiting anxiously for your reply
Thanks and regards
You can not use any SWF asset and expect it to play on mobile devices. Looks like you are using a .swf file named ZeroClipboard.swf
Hi Rob,
I'm not sure about what you said.
I blocked Flash from my desktop browser (Firefox) and can hear the sound.
Here a codeview from Firefox Firebug:
I think the sound should play also on a mobile device. Cannot test right now.
Uwe
I think you are right, but it's not playing on my iPad mini
I was looking at the no sound version, which is loading a .SWF file. A first step would be to make sure there are no .swf assets placed in the InDesign document.
Hi Rob
I have not placed any .swf in my Indesign document
Hi Mohammad,
your case is clear. Rob tested your Publish Online doc with his iPad mini.
And he confirmed that the sound is not working.
Why? We simply don't know.
Maybe a bug?
I would write a bug report on that. Package all the files, zip the package, upload it to Dropbox or a similar service and provide the download link with the report. Report here:
Feature Request/Bug Report Form
Uwe
Hi Laubender
Thank you very much for your help and support.
I have reported this issue on Bug Report Form and also gave the Dropbox link to download the files.
Thanks and regards
Nasir
I think I am not able to describe my issue properly.
Lets try again to explain my problem. just forget swf file format for the time being.
I have published a doc online using InDesign CC and this document contains only one JPG file and text (no swf file there), this online doc working perfectly on computers, whoever receive the link is able to see this published online document on his/her computer with everything such as links, animations, sounds etc working perfectly.
Now the problem: When I try to visit the same published online document on cell phone everything works but only sound do not play.
I just wants this document to run on mobile phones smoothly as it is running on computers.
Hope I have successfully explained my problem..
Hi all
Any update regarding my issue
HI Mohammad,
I have looked for answers myself and I can't find any.
I am new to the indesign online publish feature.
Have the latest version of cc 2017 programs, run on windows 7.
My document has sound (Mp3 Files) and they work perfectly on desktops and laptops, but NO SOUND on an mobile device.
I reported the bug and still heard heard nothing.
Does anyone have any answers? AM I missing a setting?
Should a new thread be started?
Help appreciated.
David
Can anyone from the Support Team for the Online Publishing in Indesign help with the issue of no sound in our published documents on MOBILE devices.
Everything works fine on desktops and laptops.
David B
Hi David
did u find the solution
NOOOOOOOOOOOOOPEEEEEEEEEEEEEE.
I even reported the bug and I have not heard a peep.
Not here or contacted in anyway.
Seems like no one is listening.
Wish we both had an answer. People keep asking me why no sound on my publication on the ipads and mobile devices.
Sorry Mohammad
i also use ONLY mp3 and mp4's in my document and don't use SWF.
And sorry Mohammad...just to let you no I have not heard one word from Adobe on this issue.
David
