I need to set blend mode for artwork to multiply in Indesign CS 6 through Javascript:
myLinkFile = myFrame.place (myFile);
myFile.blendmode = multiply;
But I was not able to find it in Object Model Viewer.
Thank you.
Yulia
Hi Yulia,
see into:
Adobe InDesign CS6 (8.0) Object Model JS: TransparencySetting
Climb up in the hierarchy of objects to get to e.g. contentTransparencySettings etc.pp. if needed.
Here an example with transparencySettings :
// Example
// Select an object on the page
var item = app.selection[0];
item.transparencySettings.blendingSettings.properties =
blendMode : BlendMode.MULTIPLY ,
opacity : 50 ,
isolateBlending : false ,
knockoutGroup : false
Best download the iChm files to search in DOM documentation by Jongware here:
Uwe
Yes, thank you, it did work. I had to remove opacity, but all else is good:
Yulia
Hi Yulia,
why do you like to set the blendmode to the contents of variable myFile ? Your code is suggesting this.
I guess, there is actually a file object stored with this variable. You cannot set transparency to a file stored in your system.
For that you would like to open it in the creator app and set transparency there.
Instead you would set transparency to a placed "thing" on a page in InDesign that could be anything depending on your file type.
An image, a vector graphic, a PDF etc.pp.
So check what's in variable myLinkFile that is returned by method place() :
$.writeln(myLinkFile);
But be not misguided what you see with that. Also ask:
$.writeln(myLinkFile.constructor.name);
And if that's clear, also do:
$.writeln(myLinkFile.length);
And maybe you want to know:
$.writeln(myLinkFile[0].constructor.name);
And now think about what object you like to set to multiply.
The "thing" inside the frame?
( Could also be outside the frame depending on the file type you are placing even if you do myFrame.place() )
myLinkFile[0]
or the frame, that would be:
myFrame
That frame could be also defined as:
myLinkFile[0].parent
But it's not sure if myFrame and myLinkFile[0].parent is always the same object.
Look up this:
Adobe InDesign CS6 (8.0) Object Model JS: Rectangle
Would variable myLinkFile always be of length 1 ?
Depending on the file type—see into IDMS snippet files—the length could be different.
E.g. if the IDMS snippet file you want to place contains several ungrouped page items.
Uwe
Hi Uwe,
You are absolutely correct. It did not work when I used it on File object, so I tried it on the rectangle object containing the file and it did work.
Thank you.
