Hello Friends,
I am exporting a file as a TIFF file by using this code
AIDictionaryRef abc = NULL;
const char *fileFormatName = "TIFF";
err = sAIDocument->WriteDocumentWithOptions(parent_dir, fileFormatName, kFileFormatExport | kFileFormatWriteAs | kFileFormatWrite, NULL, false);
It's exporting properly.
During export it's shows a TIFF Option dialog like this
How to set the this Resolution value without opening this dialog .
What is the code for this.
Please guide me.
Regards
Kundan
A little late but better than never, here's how I solved it for our use case. When creating the parameter dictionary for RasterExport(...), we're not given a resolution key to pass in (I'd assume it would be in AITIFFKeys.h with the others but it is not). So, it relies on the resolution you set in the Rasterize(...) step.
// If you look at the comments in AIRasterExport.h for RasterExport(...)
// you'll see that the AIArtHandle doesn't have to be rasterized and that
// the API will do that for you. Yeah, from what I can see, that's a lie.
// We'll need to create an ArtSet of the selected art and then
// rasterize it on the temporary document we create. Rasterize(...) buffers
// out the rasterization to a new AIArtHandle which we'll use for RasterExport(...)
AIArtSet artSet;
sAIArtSet->NewArtSet(&artSet);
sAIArtSet->SelectedArtSet(artSet);
AIRealRect rect;
sAIRasterize->ComputeArtBounds(artSet, &rect, false);
AIColorConvertOptions colorConvertOptions;
colorConvertOptions.purpose = AIColorConvertOptions::kDefault;
AIRasterizeSettings settings;
settings.type = kRasterizeRGB;
settings.resolution = 96;
settings.antialiasing = kAIAntialiasNone;
settings.options = kRasterizeOptionsNone;
settings.ccoptions = colorConvertOptions;
settings.preserveSpotColors = true;
AIArtHandle rasterHandle;
AIErr error = sAIRasterize->Rasterize(
artSet,
&settings,
&rect,
AIPaintOrder::kPlaceDefault,
0,
&rasterHandle,
NULL
// When you manually export as Tif in AI, you'll get a dialog that asks
// for resolution and other options. AFAIK, we'll have to use the resolution set
// in the rasterization above since the RasterExport options don't include or expose
// a key for setting the resolution.
AIDictionaryRef dict;
sAIDictionary->CreateDictionary(&dict);
sAIDictionary->SetBooleanEntry(dict, sAIDictionary->Key(kAITIFFLZWCompressionOption), true);
sAIDictionary->SetIntegerEntry(dict, sAIDictionary->Key(kAITIFFAntiAliasOption), kAIAntialiasNone);
sAIDictionary->SetIntegerEntry(dict, sAIDictionary->Key(kAITIFFColorModelOption), kAIRGBColorModel);
error = sAIRasterExport->RasterExport(rasterHandle, filePath, kAIFormatTIFF, dict);
sAIDictionary->Release(dict);
If you need to export everything on the page, you could do this before creating the ArtSet:
sAIActionManager->PlayActionEvent(kAISelectAllAction, kDialogOff, NULL);
Hope this helps the next guy.
