i try to instal cf2016 on window server 2012 and apache 2.4
When I arrive to "add Web server configuration" and I select apache and insert "configuration directory" and "directory and file name..", the system return an error "install web server to configure connector" (see attach).
The web server is installed. You can see to this url that point to root http://93.186.252.11/
Can you help me?
Many thanks
Marco
Please select the Configuration directory only, don't select the httpd.conf file. If that won't help, please install ColdFusion with Built-in web server and then create the connector using wsconfig utility.
Priyank
