Hello,
I'm using the After effect SDK to develop a video effect plugin (both for Premiere and AE) and I'd like to open a custom window when the user clicks on (during PF_Cmd_DO_DIALOG selector and typically to allow the user entering its activation keys).
After searching the forum it seems that the best way is using JavaScript by installing the Premiere Pro/After Effect SDK for panel scripting. I'd like to know if this is the best way to do that or is there an easier way?
Thx for your help!
when you're creating an effect this will (at first) appear in the effects pane and not an invididual panel. Of course you can then have a "button" which will launch a separate UI. My guess is this is more straightforward to implement with the C++ SDK, not using JavaScript and HTML5. To my knowledge the latter don't have any direct interfaces to the effects pane, so you'd be stuck quite soon.
Erik's right, if you're writing an effect plug-in in C++, just put the dialog in C++. The Checkout sample responds to PF_Cmd_DO_DIALOG.
