I generated several text frames (gave them variables and labels), now I would like to give all of the at once paragraph properties (font, size, ...):
I did it like this (now the labels are in the array) and also with the variables of the text frames in the array, but it doesn't work. If I write something in my generated text frames it is standard font of InDesign?! (I'm using CS6):
for (var a = 0; a < 19; a++) {
myGB_TF_Chef[0] += myTF_gapChef;
myGB_TF_Chef[2] += myTF_gapChef;
var myNextChefTF = myMasterSpread.textFrames.add({
geometricBounds: myGB_TF_Chef,
label: "NextChef"});
// define the format of the text frame, regular, nothing special
var myNextTF_array = [NextFoFe, NextKuerzel, NextSAP, NextTitle, NextChef];
var myPara7 = myNextTF_array.paragraphs[0];
myPara7.properties = {
appliedFont: app.fonts.item("InfoOTText"), // which font is used
fontStyle: "Regular", // bold or regular or italic
pointSize: 12, // which font size is used
justification: Justification.leftAlign // should the text be left, center or right aligned
}; // end of description of first TextBox
Any idea what I did wrong? Can't I put variables or labels in an array?
Best
Cleo
Have something to add?
