Walk recording does not seem to work for swapping of walk-modes…
Engaged ,
Jun 20, 2017 Jun 20, 2017
…or am I missing out on s.th.?
When I tried to record a scene with a puppet with a walk behaviour, I could not record different walk modes.
This is what happened:
1.) I recorded a scene and used different walk modes on the recorded puppet.
2.) When I play that recorded scene only the last walk mode I had used would appear on the whole scene.
3.) Then I tried recording only one walk mode at a time.
4.) When I played the recording, though, again only the last walk mode I used would be shown.
Is this a bug or do I misunderstand the new behaviour.
In either case:
Is there a way to record (and FIX or CHANGE) different walk modes (i.e. walk, run, etc.) within a recording/a scene/a puppet's timeline?
(I imagine I could use the same puppet again and again for each walk mode but that is obviously not a very good solution…)
Thank you!
825
Adobe Employee , Jun 20, 2017 Jun 20, 2017
It's a little complicated but you'll need to arm and record "start" as well, and "keyboard input" if you're using the arrow keys. Without those, CH isn't sure when to start/switch.
So here I recorded a start: immediately and style:walk, then two more takes with style:prance and style:run, and it worked.
Not the most intuitive way to do things, agreed - but this should work.
From what I noticed under the "Walk " properties, you need to check if the recording button is active/armed (red). Otherwise if not active/armedstyle-armed.jpg, it records  nothing and on playback seems to just play whatever default setting you have whether its a run , walk ..etc. I am not sure if its what you were asking but I am sure Oksamurai will help.
Engaged ,
I'm not sure.
Thing is, for example, once I HAVE already made a recording, when I play it back, the walk behaviour shows whatever mode is active then, not the one(s) that were while I was recording.
It seems an error to me, but I'm not sure, that's why I posted this here and not in the Bugfix dept. of the forum…
Engaged ,
But it might have s.th. to do with my issue anyway, so thank you for that input!
Adobe Employee ,
Engaged ,
A solution is a solution is a solution. Thank you so much for all of this lightning quick always helpful support!!
