Hi.
By default Indesign 2015 has the following signature sizes: 4, 8,12,16, 32.
I'd need to have a different signature size. For instance 20 (which is OK, because it's 4x5).
How can I do it?
Thanks in advance.
Regards.
Diogo
Print Booklet is designed for very simple projects. I think you're limited to what it has to offer. As far as I know, it's not scriptable.
If you're a designer, you should have the printer do the imposition. If you ARE the printer, look elsewhere for imposition software for something more complex. Do a Google search for "PDF imposition" so see the choices available.
I’m afraid I have no idea what you’re referring to. If you’re talking about document presets you can create your own.
InDesign has no default signature sizes. I also don't know what you're talking about.
This is what I'm refeering to. When making a Print Booklet you have to define a Signature Size. I'd like to be able to define a signature size different than the ones predefined. How can I do it?
(Please see the example in my reply to Steve).
