I’ve layered an image of me on top of this image and I want to know if there are any techniques to make it look like I am actually laying in the pile of pigs instead of just on top of the pile.
IMO with the image I would think not for several reasons. The Image itself look flat the pigs do not even look like that are in as stack. Even a child image scale to the appropriate sizie to relative to the toy pigs size would be so large all the pig would be covered none would be visible.
Moved to Photoshop forum
it definitely helps to have two photos that match up. Just knowing Photoshop definitely doesn't mean you can make any two images together. Not sure how much photoshop you know... tough to teach the entire program in the forum.
You could use a MASK. You would have to select the background of the image with you in it, and Mask out the background.
then you can mask out parts of the pigs so that it looks like they are on top of you.
You can click the mask button at the bottom of the Layers panel (see attached), draw with black to hide parts of the image, and use white to put it back.
this might be challenging for a beginner.
good luck!
mark
Hey, I just responded to this on Quora!
