How to assign blend mode to a graphic in indesign CS6, javascript
Participant ,
Jun 19, 2017 Jun 19, 2017
I need to set blend mode for artwork to multiply in Indesign CS 6 through Javascript:
myLinkFile = myFrame.place (myFile);
myFile.blendmode = multiply;
But I was not able to find it in Object Model Viewer.
Thank you.
Yulia
Scripting
878
Hi Yulia,
see into:
Adobe InDesign CS6 (8.0) Object Model JS: TransparencySetting
Climb up in the hierarchy of objects to get to e.g. contentTransparencySettings etc.pp. if needed.
Here an example with transparencySettings :
// Example
// Select an object on the page
var item = app.selection[0];
item.transparencySettings.blendingSettings.properties =
    blendMode : BlendMode.MULTIPLY ,
    opacity : 50 ,
    isolateBlending : false ,
    knockoutGroup : false
Best download the iChm files to search in DOM documentation by Jongware here:
Indesign JavaScript Help
Uwe
Participant ,
Jun 20, 2017 Jun 20, 2017
Yes, thank you, it did work. I had to remove opacity, but all else is good:
Yulia
Hi Yulia,
why do you like to set the blendmode to the contents of variable myFile ? Your code is suggesting this.
I guess, there is actually a file object stored with this variable. You cannot set transparency to a file stored in your system.
For that you would like to open it in the creator app and set transparency there.
Instead you would set transparency to a placed "thing" on a page in InDesign that could be anything depending on your file type.
An image, a vector graphic, a PDF etc.pp.
So check what's in variable myLinkFile that is returned by method place() :
$.writeln(myLinkFile);
But be not misguided what you see with that. Also ask:
$.writeln(myLinkFile.constructor.name);
And if that's clear, also do:
$.writeln(myLinkFile.length);
And maybe you want to know:
$.writeln(myLinkFile[0].constructor.name);
And now think about what object you like to set to multiply.
The "thing" inside the frame?
( Could also be outside the frame depending on the file type you are placing even if you do myFrame.place() )
  • myLinkFile[0]
    or the frame, that would be:
    myFrame
    That frame could be also defined as:
    myLinkFile[0].parent
    But it's not sure if myFrame and myLinkFile[0].parent is always the same object.
  • Look up this:
    Adobe InDesign CS6 (8.0) Object Model JS: Rectangle
    Would variable myLinkFile always be of length 1 ?
    Depending on the file type—see into IDMS snippet files—the length could be different.
    E.g. if the IDMS snippet file you want to place contains several ungrouped page items.
  • FWIW: If you do method place() on a graphic frame with an IDMS snippet file the contents will placed on the spread where the graphic frame resides. And not in the frame. No error message…
  • Regards,
    Uwe
    Participant ,
    Jun 22, 2017 Jun 22, 2017
    Hi Uwe,
    You are absolutely correct. It did not work when I used it on File object, so I tried it on the rectangle object containing the file and it did work.
    Thank you.
