HI,
The following steps are doing.
1) Open two indesign files. One is source and another one is final file.
2) Based on modified date I need to create the png with file naming as _source and _final.
mains();
function mains() {
var docSou = app.documents[0];
var docFin = app.documents[1];
var SouName = File(docSou.fullName);
var FinName = File(docFin.fullName);
var modifiedDate1= SouName.modified;
var modifiedDate2= FinName.modified;
mycheck1();
function mycheck1(){
if(modifiedDate1<modifiedDate2){
var docName =docSou.name.replace(/\.[^\.]+$/, '_source');
set_png_export_options();
var file = new File("~/Desktop"+"/"+docName+".png");
docSou.exportFile(ExportFormat.PNG_FORMAT, file);
mycheck2();
exit();
else{
var docName =docFin.name.replace(/\.[^\.]+$/, '_final');
docFin.exportFile(ExportFormat.PNG_FORMAT, file);
mycheck3();
exit();
function mycheck2(){
function mycheck3(){
function set_png_export_options() {
with(app.pngExportPreferences) {
antiAlias = true;
embedColorProfile = true;
exportResolution = 1600;
exportingSpread = true;
PNGColorSpace = PNGColorSpaceEnum.RGB;
PNGExportRange = PNGExportRangeEnum.EXPORT_ALL;
PNGQuality = PNGQualityEnum.MAXIMUM;
simulateOverprint = false;
transparentBackground = false;
useDocumentBleeds = true;
But it always show the first document as _source.
Could you please suggest where I am missing.
K
Any suggestion please, I know I am very close to the solution, but not able to find out that!!
K
I am not sure what you are trying to achieve.
But I am wondering why you are exporting twice.
In the function mycheck1:
Inside IF you export to file with "_source" name.
Also you call mycheck2() which exports to file with "_final" name.
Same in the else block also.
So, essentially you seem to overwrite the file.
Please check if you intend to do so.
I believe with some traces you should be able to figure out.
Thanks for your reply. If you see the first code, I am taking two indesign file. One is source and another one is final file. So I am exporting twice. So i not overriding.
K
As I see the following code,
Whether it is the IF or the ELSE that is executing:
The first document is always tagged as "_source"
The second document as "_final"
Did you intend to do so above?
Or did you intend to switch the source and dest doc as per modified file, which seems missing.
Ye, but am taking the modifiedDate for each document and checking whether first document is old or not. If it is old means it tagged as source then it go to the mycheck2() function. This function will give the second document as Final.
I am not sure I am explained clearly
I found the mistake I did.. here is final script working good..
mains();
function mains() {
mycheck1();
mycheck2();
exit();
else{
var docName =docSou.name.replace(/\.[^\.]+$/, '_final');
mycheck3();
exit();
var docName =docFin.name.replace(/\.[^\.]+$/, '_source');
antiAlias = true;
Thanks for interest vinothr
That is what I meant. You didn't swap the source and final, which you have done now (in ELSE block):
TO
