I am new to Adobe Stock and am trying to submit my first photos. I have some identifiable buildings that are over 120-years-old and are not on the list of known properties.
How do I answer the release question? How do I communicate that I don't believe a release is needed?
I have found the contact us feature almost unusable for this question. I had asked another question about filenames and receive a prompt answer so I just sent the nice guy a new question via that email trail. (don't know if that will work)
Anyone been down this road and know what I need to do to upload these files correctly?
Kevin
Hi Kevin,
I've already answered the ticket you sent. You can select no to the question about recognizable property if a release is not required. The moderators may disagree with that and reject the content so keep that in mind.
regards,
Mat Hayward
Mat, you are helpful and prompt.
Tell the bosses you need a raise.
K
I was asked for a "property release" for my own abstract digital painting. It's a bit weird and I do not know what to do. The picture looks a bit like watercolor, but it's not a reproduction.
We have no way to know if the artwork was created by you or someone else and photographed by you. As a result, we require a property release. Since you are both the property owner and the contributor you will need to print your name and sign it in both locations (witness name and signature is also required).
Best regards,
Mat Hayward
I will share the info that I received from the most helpful Adobe employee Mat.
"If a release is not needed you can select no when asked if there is recognizable property. The final decision is up to the moderation team however. If they determine that a release is needed then the image will be rejected and that decision is final. We can't possibly know of every building and location in the world so the list of known image restrictions is limited to the most commonly requested spots."
I suggested that they add a feature where we could upload notes for the reviewer.
Hope this helps others.
K
