I'm using Photoshop on Windows 10 Insider Preview Build 16215, with the latest system and driver updates. Photoshop can open files, but when files are opened, it shows the tab with the file name, but nothing on below it, like this:
Is this just me or everybody else running the insider preview also have this problem? In Feedback Hub there is someone who posted that Adobe Premiere, Bridge, and Camera Raw does not show images and videos.
This is on the PSErrorLog.txt file:
2017:06:21 18:21:37 : 00000000000017F0 of type struct _ADsc * __ptr64 not found : 1 : REQUIRE failed
2017:06:21 18:21:37 : e:\ps17\ps_18_win_x64_daily_retail\20161012.r.53\photoshop\main\photoshop\interfaces\UTrackResourceImp.h : 137 : REQUIRE failed
2017:06:21 18:21:37 : 0000000000001750 of type struct _ADsc * __ptr64 not found : 1 : REQUIRE failed
2017:06:21 18:21:37 : 0000000000000308 of type struct _ALst * __ptr64 not found : 1 : REQUIRE failed
2017:06:21 18:21:37 : 0000000000001300 of type struct _ADsc * __ptr64 not found : 1 : REQUIRE failed
2017:06:21 18:21:37 : 0000000000001260 of type struct _ADsc * __ptr64 not found : 1 : REQUIRE failed
2017:06:21 18:21:37 : 00000000000002A0 of type struct _ALst * __ptr64 not found : 1 : REQUIRE failed
2017:06:21 18:21:37 : 0000000000000FB8 of type struct _ADsc * __ptr64 not found : 1 : REQUIRE failed
2017:06:21 18:21:37 : 0000000000000F18 of type struct _ADsc * __ptr64 not found : 1 : REQUIRE failed
2017:06:21 18:21:37 : 0000000000000240 of type struct _ALst * __ptr64 not found : 1 : REQUIRE failed
2017:06:21 18:21:37 : 0000000000000EA0 of type struct _ADsc * __ptr64 not found : 1 : REQUIRE failed
2017:06:21 18:21:37 : 0000000000000E00 of type struct _ADsc * __ptr64 not found : 1 : REQUIRE failed
2017:06:21 18:21:37 : 0000000000000218 of type struct _ALst * __ptr64 not found : 1 : REQUIRE failed
2017:06:21 18:21:37 : 0000000000000D70 of type struct _ADsc * __ptr64 not found : 1 : REQUIRE failed
2017:06:21 18:21:37 : 0000000000000CD0 of type struct _ADsc * __ptr64 not found : 1 : REQUIRE failed
2017:06:21 18:21:37 : 00000000000001F0 of type struct _ALst * __ptr64 not found : 1 : REQUIRE failed
2017:06:21 18:21:37 : 00000000000005E8 of type struct _ADsc * __ptr64 not found : 1 : REQUIRE failed
2017:06:21 18:21:37 : 0000000000000548 of type struct _ADsc * __ptr64 not found : 1 : REQUIRE failed
2017:06:21 18:21:37 : 00000000000000F8 of type struct _ALst * __ptr64 not found : 1 : REQUIRE failed
2017:06:21 18:21:37 : 0000000000001578 of type struct _ADsc * __ptr64 not found : 1 : REQUIRE failed
2017:06:21 18:21:37 : 0000000000000410 of type struct _ARef * __ptr64 not found : 1 : REQUIRE failed
2017:06:21 18:21:37 : 0000000000001570 of type struct _ADsc * __ptr64 not found : 1 : REQUIRE failed
