Is there a way to render video in a script or batch so that the images will either save sequentially from the previous images saved, or into a new folder?
I am trying to render a video into an image sequence, than transforming position, and then rendering it again, a total of 900 times, but the images are saving over themselves or not saving at all.
I am able to render the video into an image sequence the first time, but when I try to run a script that will transform the image position, than render a second time, the image sequence does not render, or it renders over the previously rendered images.
It would be okay to have a continuous sequence past jpg 900.. 901.. 902.. 903..
I haven't checked if this is possible, but if you install the scriptListener plugin, then render a video, it should provide you with the code. Then you just need to exchange the file save info in that code with a variable that you can sequentially increase the file number.
Thanks Chuck,
That is a great idea. I downloaded script listener and gave it a shot. I got the code but unfortunately I don't know enough programming to manipulate the string. Do you? I'm guessing the line desc8.putString( idNm, """Line02.jpg""" ); would be the one to change.
Also once it's finished is it fairly easy to re-implement it back into an action?
var idExpr = charIDToTypeID( "Expr" );
var desc7 = new ActionDescriptor();
var idUsng = charIDToTypeID( "Usng" );
var desc8 = new ActionDescriptor();
var iddirectory = stringIDToTypeID( "directory" );
desc8.putPath( iddirectory, new File( "/Users/jacksonnotier/Desktop/Dark Peony/JPG_Sequences/PS/Line_02" ) );
var idsubdirectory = stringIDToTypeID( "subdirectory" );
desc8.putString( idsubdirectory, """Line_02""" );
var idNm = charIDToTypeID( "Nm " );
var idsequenceRenderSettings = stringIDToTypeID( "sequenceRenderSettings" );
var desc9 = new ActionDescriptor();
var idAs = charIDToTypeID( "As " );
var desc10 = new ActionDescriptor();
var idEQlt = charIDToTypeID( "EQlt" );
desc10.putInteger( idEQlt, 5 );
var idMttC = charIDToTypeID( "MttC" );
var idNone = charIDToTypeID( "None" );
desc10.putEnumerated( idMttC, idMttC, idNone );
var idJPEG = charIDToTypeID( "JPEG" );
desc9.putObject( idAs, idJPEG, desc10 );
desc8.putObject( idsequenceRenderSettings, idsequenceRenderSettings, desc9 );
var idminDigits = stringIDToTypeID( "minDigits" );
desc8.putInteger( idminDigits, 7 );
var idstartNumber = stringIDToTypeID( "startNumber" );
desc8.putInteger( idstartNumber, 0 );
var iduseDocumentSize = stringIDToTypeID( "useDocumentSize" );
desc8.putBoolean( iduseDocumentSize, true );
var idallFrames = stringIDToTypeID( "allFrames" );
desc8.putBoolean( idallFrames, true );
var idrenderAlpha = stringIDToTypeID( "renderAlpha" );
var idalphaRendering = stringIDToTypeID( "alphaRendering" );
desc8.putEnumerated( idrenderAlpha, idalphaRendering, idNone );
var iduseDocumentFrameRate = stringIDToTypeID( "useDocumentFrameRate" );
desc8.putBoolean( iduseDocumentFrameRate, true );
var idvideoExport = stringIDToTypeID( "videoExport" );
desc7.putObject( idUsng, idvideoExport, desc8 );
executeAction( idExpr, desc7, DialogModes.NO );
Yes, that's it. I think you want to get rid of all the quotes and replace it with a variable.
Yes you can use it in an action. You just record the action and play the script.
