Locked
Header will not keep Centered on Different Pages
Jun 22, 2017 Jun 22, 2017
Hey All,
I am new to muse and I have been working on a website but I am having a problem.
I have a Header move left to right on different pages within the website. The main page it is centered but on the other two web pages I have created the header moves to the right a good bit and is no longer centered.
I am using 1 master where the Header and Footer are which is being applied to all the web pages.
Can someone help me, Please? I have tried to troubleshoot it myself but I am not getting anywhere.
Chris
187
New Here , Jun 22, 2017 Jun 22, 2017
Thank you all for all the help!
I was not able to solve it based on the ideas you had but I finally noticed that 2 of the pages had a different breakpoint that was wider than the master and the home page.
Solved!
Thanks again,
Chris
Please check thoroughly, if there are objects overlapping/placed outside the page/breakpoint width.
Don’t forget to check your master page as well.
It is easy to find those objects, by zooming out and performing a „Select All“ (Cmd+A).
If you can’t ind a solution, do the following:
Reduce your  site to only one typical page, containing a few elements, which demonstrate your issue. (This is necessary, because it saves download- and analysing-time. In addition: By doing this, it is likely, that you find the „misbehaving“ elements by yourself).
Upload this reduced .muse file (without assets) to Dropbox or a similar file sharing service and provide the download link here. Then we can have a closer look.
Thus, time consuming „question and answer“ games or pure guessing can be considerably reduced.
I´m pretty sure that it is very easy to solve, if we just could have a look at a .muse : simply one page, with your master.
Did you set up the following pages all the same?
For the beginning even a link to a BC-uploaded-provisionally website could help before we dive in too deep.
Best Regards,
Uwe
Solved!
Thanks again,
Chris
I asked you if you set up the following pages all the same. You didn´t. What more do you want?
But good that you found it for "yourself"
Best Regards,
Uwe
