Hello,
I freshly installed my PC and set up the Adobe CC overnight... I made a little mistake however and clicked on LR instead of CC because I thought I'd get the usual Adobe CC App where I could add the other programs... When Is aw that it tried to install the LR Application I aborted and used the Adobe CC APP... however each time I try to install Lightroom 2015 CC I get LR 6.x I removed it a few times... signed off, signed on, even copied the old LR 2015 files that I had in use yesterday and Lightroom still says it is Version 6.x over Lightroom 2015 CC
The Adobe Creative Could App says I could use Lightroom 2015 CC... So I am a bit confused of what to do... I am using Win 10 Pro x64...
thanks for the help,
Tom !
That may be true, but I wanted to install Lightroom CC and not 6.10.1
I once again removed everything... every file and folder that used the name Lightroom, Adobe, Creative Cloud, I removed everything inside the registry... all License and Account files... I created a new Adobe ID just to TEST if it was my Adobe ID and I reinstalled Lightroom just to AGAIN get Lightroom 6.10.1 instead of Lightroom CC
Fortunately I came across this thread How do I upgrade from Lightroom 6 to Lightroom CC
Just to Qu
uninstall everything cc including preferences, https://helpx.adobe.com/creative-cloud/help/uninstall-remove-app.html
then uninstall the cc desktop app, https://helpx.adobe.com/creative-cloud/help/uninstall-creative-cloud-desktop-app.html
clean your computer of cc files per http://www.adobe.com/support/contact/cscleanertool.html
restart your computer (don't skip this)
reinstall the cc desktop app, https://creative.adobe.com/products/creative-cloud.
if you're unable to install the cc desktop app at this stage, use an administrator account (solution 3 here, https://helpx.adobe.com/creative-cloud/kb/creative-cloud-missing-damaged.html)
use the desktop app to install your cc programs/trials
[moved from Downloading, Installing, Setting Up to Creative Cloud Download & Install]
Thank You, I will do that and get back to you. I have a 1 MBit line so it will take a while
you're welcome.
p.s. if you have a slow connection make sure your computer doesn't go into 'sleep' mode during the download/installation.
So the creative Cloud App still says
"Lightroom CC 2015"
while Lightroom itself says
Lightroom 6.10.1
ZzzZZzZZZz
Any further tipps?
that's the current version.
[moved from Creative Cloud Download & Install to Photoshop Lightroom]
Just to Quote it here for the Lazy
By John Waller:
"Once you've opened Lightroom 6, deactivate it via Help > Sign Out.
You can then close Lightroom and re-launch it. You should then have the option to Sign In with your Adobe ID and you should get Lightroom CC."
That was really all that was needed... Reinstalled Adobe Cloud and LR 4 times before I found that out... Thank You John!
