Friends and gurus: I encounter a very strange situation!
The following script works correctly. The functions are called by a button.
#target framemaker
var gasETBViewSettings = []; // save the user settings
var gsETBMsgNoDoc = { en: "No document active!",
de: "Kein dokument aktiv!"
// alert ("ETBToggleViewsA really entered");
SetUpMenu();function SetUpMenu() { // ==== Define the menu - even if not used =================================
var sLabelEditing, sLabelPrinting, menuLocation, cmdDoc1, cmdDoc2;
menuLocation = app.GetNamedMenu("ETBdummy"); // Required, even if not used
cmdDoc1 = DefineCommand (1, "EditingDisplay", "Document Editing Display [ETB]", "\!qqe");
cmdDoc2 = DefineCommand (2, "PrintingDisplay", "Document Printing Display [ETB]", "\!qqp");
UpdateMenus();
} // --- end SetUpMenufunction Command(cmd) { // ==== Respond to menu/TB command ==================================
alert ("ETBToggleViewsA command " + cmd + " entered");
switch(cmd) {
case 1:
SetEditingDisplay();
break;
case 2:
SetPrintingDisplay();
break;
} // --- end Commandfunction SetEditingDisplay () {
alert ("SetEditingDisplay entered"); // of course there is more in here
function SetPrintingDisplay () {
alert ("SetPrintingDisplay entered"); // of course there is more in here
But if I insert the following after line 11, then the script does not work anymore (it is loaded, but the Command function does not issue the alert etc.).
sLabelEditing = { en: "Document Editing Display [ETB]",
de: "Ansicht für Dokument Bearbeitung [ETB]" };
sLabelPrinting = { en: "Document Printing Display [ETB]",
de: "Ansicht für Dokument Drucken [ETB]" };
It doesn't work either if I place the following after line 06:
var gsLabelEditing = { en: "Document Editing Display [ETB]",
var gsLabelPrinting = { en: "Document Printing Display [ETB]",
I have similar constructs in various scripts with no problems so far.
What is going on here?
Guess What?
After carefully checking differences between a working stub and the full script I discovered the difference:
The script must be coded in UTF-8 (it was Windows code page 1252).
Wouldn't be a message about this possible?
Klaus
Since I had a problem with Windows update (see https://forums.adobe.com/thread/2346713) even this simple script does not work anymore - neither in FM-14.0.0.361, nor in update 1 nor in update 2.
The menu set up function is run on start of FM, but the command function is not invoked - neither by shorcut nor by a button which specifies the command.
This is a very stripped down version of the real script, which can be found on my website. It works if invoked in test mode - without menu set up.
The absolute wierd thing is that all this has worked before the roblem with the Windows update (both build 361 and 406 - 415 was'n there at that time).
All the other scripts I now have in the Enhanced Tool Bar work as intended. They are in the Startup folder and are invoked by button (Insert Symbol also by menu item):
ETBinsertSymbol_en.jsx has Notify function to bypass initial start, sets up menu items, used by button
ETBSaveAsOld.jsx with similar set up
ETBtest.jsx just a stub with similar setup
Guess What?
Klaus
