RoboHelp 11 - Print index
Jun 22, 2017 Jun 22, 2017
My problem started because I have to delete several topics in my help file. I started small by deleting two bullet entries with bookmarks. Then I got broken links to the index and I'm trying to find where they are. RH's instructions for printing index do not seem to apply to version 11. When I click the Index pod, nothing happens. When I click the Create/View Index file and select the default index, nothing happens.
It would be quite helpful to have a printed index that I can search, so I would appreciate your suggestions.
Dimi
609
LEGEND , Jun 22, 2017 Jun 22, 2017
If you want to print the index, I might suggest Tools > Reports > Index.
Can you attach a screenshot (use the web interface) to show us what you're seeing?
The instructions to print say to click the Index pod and, from the pop-up menu, select the items to print. Then, in the toolbar, click print. Finally select the properties. However, clicking the Index pod does nothing. Right-clicking does nothing. I'll post a separate reply about the missing link thing.
The problem started when I deleted a paragraph with a bookmark. This action resulted in two broken links, both the index, as evidenced by the key icon in Topic References.
I cannot find an entry "diagonal" in the index and showing topic links is no help at all, because you cannot distinguish bookmark links. Never mind the fact that the topic has hundreds of links.
When I select Edit in the above window, I get this window.
I don't understand why the Title and the Link to are identical. 1D_diag_line is the bookmark, but nothing in the All Folders section is highlighted.
I'm quite frustrated and will have to delete quite a few bookmarks in the coming days, so I'm very thankful for any help you can provide.
Dimi
Normally when you delete something in RoboHelp, it will handle any links so that you don't end up with Broken Links.
Perhaps you might try deleting the CPD file and see if that helps?
Click here for information on how to do that
Cheers... Rick
Additionally, if you are looking at the Index pod, if there are terms that aren't mapped to topics, they should be presented in Bold. Not only that, but they should not appear in the output.
Cheers... Rick
Yep, I have those taken care of.
Dimi
Printing to PDF of the Index would probably have to go through the Printed Documentation route - RH to Word to PDF
Jun 23, 2017 Jun 23, 2017
This is a bit of overkill, but I appreciate the response.
Yes, RH handles links when you delete a topic, but this was a bookmark. I did manage to find the stray entry in the index and delete it, but I would still love to know how to print the index itself, preferably to PDF.
Thanks for the info about the CPD. I will try to remember it for future problems!
Yay, this works. I also tried Adobe's support folks and, amazingly enough, the answer is easy but just not documented.
1. Click the Index pod.
2. Select File > Print Index.
Don't I feel silly!
Dimi
RoboHelp Documentation
Download Adobe RoboHelp
