I want to make a template that consists of a number of circle shapes that are cut out of a black layer. The idea is to be able to sandwich images between the cut out template layer windows and the background. I have the the background layer as white, the next layer is black and then I have a lot of layers with a circle shape on each one. I cannot figure out how to cut those circle shapes out of the black layer. Would love some help.
It easy with that set up. Here have a white background added a black layer over that. Created a yellow round shape layer and duped it 5 times and positioned them is 6 locations on top of the black layer. I then targeted the black layer. the with the shift and the ctrl keys hell down I clicked on the 6 yellow circle icons in the layers palette to select the layers pixels areas. I the hit the delete key to delete the section in the black layer. I then deleted the 6 shape layers.
Thank you so much! Did the trick. I used to use PS a lot about 8 years ago but I have forgotten so much!
You may want to look at Photoshop Photo Collage Toolkit
Photoshop scripting is powerful and I believe this package demonstrates this
The package includes four simple rules to follow when making Photo Collage Template PSD files so they will be compatible with my Photoshop scripts.
There are fifteen scripts in this package they provide the following functions:
