See below for a description of the color profile issue I'm having. This may be an obvious question but I searched extensively and couldn't find an answer. I am definitely still a noob when it comes to color management. Thanks in advance for any help!
Best,
Nate
So the answer was pretty obvious...but like I said I'm a noob. I hadn't realized it was possible to just extract an icc profile from an existing image. A number of software can do it, I used Imagemagick (see thread below for details). When I applied the extracted profile to my IM-created TIFF, I was able to perfectly reproduce the color.
http://www.imagemagick.org/discourse-server/viewtopic.php?t=17737
See this thread. XYZ Colorspace conversion Photoshop CS2 You might want CIE XYZ not Adobe.
I really don't know anything about or use this color space technology, but I can at least try to get you somewhere.
Thanks gener but I think the link I provided is the link to the CIE XYZ profiles (see link below). Someone please correct me if I'm wrong though.
Like I said, of the icc's downloadable on that site the D50 version gives the closest match to PS but it's not perfect. The reason I think the profile I'm after is an Adobe proprietary one is because I found an Adobe copyright embedded in the the PS-created image's color profile information.
XYZ is one of the two native spaces of ICC profiles. So an XYZ profile is hardly a profile at all, it's just a "do nothing" profile with some headers. I mention this because, if I was programming an app that needed to embed an XYZ profile, I'd just make one in memory: no need for an external file to exist.
No idea why Adobe would use XYZ for 32-bit images unless you converted it that way. XYZ is _not_ a kind of RGB, and so this is not going to contain RGB values, but some conversion of them. You'd have to match the conversion, not the RGB values.
Ok, from some study I think I understand that a 32-bit ("HDR") image doesn't have an RGB colour space, so there are none of the problems associated with saving with a different space. It uses a fixed space which can show every possible colour, including those outside any RGB gamut (and many imaginary colours, which I don't really understand). So, while you enter RGB values into Photoshop for a 32-bit image, they are immediately converted from the working space to XYZ; the numbers you type are never stored.
So, unless ImageMagick does the same thing, you need to specify XYZ values, not RGB.
Thanks this definitely gives me more to noodle on. Just to give some more background, I've created two TIFF files that illustrate what I'm seeing (one PS-created and one IM-created). They are both 1x1 pixel 32-bit TIFFs but if you open them in Photoshop (and zoom in) you will see the color representation is slightly different.
Solid_Green_PS.tif (PS-Created)
Solid_Green_IM.tif (IM-Created)
The only difference I can find between these two TIFF's are their color profiles. When I look at the embedded icc information for each image the PS-created one has the following:
icc:copyright: Copyright 2017 Adobe Systems Incorporated
icc:description: XYZ Profile
icc:manufacturer: XYZ Profile
icc:model: XYZ Profile
Versus the IM-created file, which shows the D50 XYZ Profile I assigned:
icc:copyright: Copyright Hewlett Packard, 2006
icc:description: D50 XYZ profile
icc:manufacturer: D50 XYZ profile
icc:model: D50 XYZ profile
So I guess my question is still the same as the OP, where do I find the Adobe XYZ .icc file that is assigned to the PS-created image so I can assign it to my IM-created image and make them perfectly match?
