Help please if you can?
My PayPal button has a comments section that should have a border around it but it does not appear in my Muse site.
I have checked with Paypal and tested the button on the w3schools testing site and the border appears but not in my Muse site.
PayPal say the issue is with my site as their button works, "The text box is not appearing on your website probably due to your website's formatting and styling. This is not related to PayPal's issue but rather due to your website's CSS styling. In this case, kindly check your website's formatting to ensure the text box will be displayed without any issues."
has anyone else had the same issue?
The comments section is there under the text but no obvious place for a user to start, as no border appears
Thanks in advance
Have you tried to tie both form and input text in a unique <div>?
<div class OR id="name for css styling" >
<form target="paypal" action="https://www.paypal.com/cgi-bin/webscr" method="post">
<input type="hidden" name="cmd" value="_s-xclick">
<input type="hidden" name="hosted_button_id" value="D4CVN78GPNJTG">
<input type="image" src="https://www.paypalobjects.com/en_AU/i/btn/btn_cart_LG.gif" border="0" name="submit" alt="PayPal – The safer, easier way to pay online!">
<img alt="" border="0" src="https://www.paypalobjects.com/en_AU/i/scr/pixel.gif
...Copy link to clipboard
Could you provide a screenshot what you want and how it appears?
Is this paypal placed by "insert html"?
Best Regards,
Uwe
Thanks Uwe
it was through insert html
As you can see below the text Special Instructions appears but below it should be a text box with a border for users to leave instructions
As I didn`t do that before – could you resize the border of the insert via html? Isn`t it like the social button widget out of muse, that you can drag the border as you like?
Couldn`t you just place a textbook below this paypal button or is it kind of interactive and may change?
Uwe
Thanks Uwe
I will try but not sure how it will interact with the PalPal shopping cart?
I tried to use the Muse PayPal Widget and you either have to add a shipping amount or leave it as $0 and it didn't register the PayPal shipping breaks that I set in the PayPal account.
Thanks for your help I will let you know how it goes
Brad
I admit, I hope that someone with deeper (maybe coding) experience could have a look at your question/issue.
How does the code look like from paypal, or where could this be inspected more properly?
Could you provide this? The more the forum knows, the better we can help, hopefully .
Best Regards,
Uwe
Thanks Uwe
I'm a bit of a novice at all this, here is the code as supplied by PayPal that is getting the results in my screen grab
<img alt="" border="0" src="https://www.paypalobjects.com/en_AU/i/scr/pixel.gif" width="1" height="1">
<td><input type="hidden" name="on1" value="Special Instructions">Special Instructions</td></tr><tr><td>
<input type="text" name="os1" maxlength="200"></td>
</form>
Cheers
Brad
<td>
</form>
</div>
Also, what does exactly the "Special Instructions" text should do?
Is it really necessary for it to be a <input>?
Hope this helps.
Thanks mtprimo
Almost there I just needed to place all the code inside the form and it works fine.
The special instructions are so the buyer can leave their product selection i.e soap for the pack they are purchasing
<td>
</div>
</form>
Cheers Brad
Great!
Just dont forget to change the <div class OR id="name for css styling">
Chooose between a class or a id, and then put a name for it, e.g <div class="paypal_button_div">
Glad it helped !
