Join us for an upcoming in-person Adobe Target Skill Builders event ~~> We're hosting these live learning opportunities to equip you with the knowledge and skills to leverage Target successfully. Learn more to see if we'll be coming to a city near you!
SOLVED
Locking the users or Campaign in Target
Avatar
Level 2
Hello,
I have question regarding how to lock a user in Target and I do not know if this is even possible. We been using Target in our company and we implemented several A/B tests for our web using Target. For us, Development team develop the experience and send it to Testing team and they will provide the final sign off and then it goes live.
Our problem here is : when testing and Development work on the same campaign at same time the parameters in the testing url's (These testing urls will be provided by Dev team through Target) will keep changing and testing would not be able to see the changes and validate it properly because both the teams are working at the same time.
I wanted to figure out if they is any way that, the testing team can lock the campaign so the development team cant make any changes while testing. When testing finish they can again unlock it for further steps.
Could anyone suggest if this is something we can do in target? This saves lots of time for us.
Thank you!
Satish
1 Accepted Solution
Avatar
Correct answer by
Level 10
Hi Satish,
As per the product team  that's not currently a feature but you can use permissions to do essentially the same thing by giving the other person editor access and it is "locked" for them and only an approver can approve it so this is solved by managing their users and controlling who is an approver and who isn't
Regards
Parit
Avatar
Level 10
Hi Satish ,
By Testing URLs do you mean preview Experience URL's which are generated before the activity is live for preview and QA purposes.
Regards
Parit Mittal
Avatar
Level 2
Hi Parith,
Thanks for your reply! Yes! Thats correct . Those are the preview urls
which we use for QA puposes.
Thank you!
Satish
Avatar
Level 2
Hi Satish,
As far as I know there is no way to lock the campaign for certain period of time while campaign is under QA in target standard or classic.
My below answer is specific to standard.
If you feel that campaign URL should not change ask dev team to just update and save offer code only not the entire campaign.
In that case  QA url might not change as offer code is only getting updated.
to update just offer code they need to create offer from offer tab given third at top.
Create offer and use that offer while creating activity. while creation of activity they can click change offer option and select created offer.
Manish Agravat
Avatar
Level 10
Hi Satish,
There is no way to lock the campaign for certain period of time while campaign is under QA in target standard or classic.
I have also reached out to Product team regarding this and will share the inputs ASAP.
Regards
Parit Mittal
Avatar
Correct answer by
Level 10
Hi Satish,
Regards
Parit
