I have been tasked with creating a catalog with a large group of photos from photoshoots. Currently, I only have Bridge CC but, in 3 months time when my workplace renews/upgrades their Creative Cloud subscription, we will all have Lightroom. My question is: if I start now by assigning keywords to these photos in Bridge, when the time comes to import them into Lightroom, will the keywords import along with the photos they are assigned to? I'd hate to do all the work and then have it not carry over into Lightroom.
Windows 10, if it matters.
Hi fayster01,
Lightroom should pick up on the keywords you entered via Bridge if you have it set to write the keywords out to the file (or XMP in the case of RAW).
If you have keywords that aren't already assigned to pictures, and you want to import your full list into LR, you can Export your keyword list from Bridge (via the flyout menu in the Keywords panel) and Import your list into Lightroom (via the Metadata menu). Or just apply them all to one picture and import that is a pretty quick way to
...Copy link to clipboard
Hi fayster01,
If you have keywords that aren't already assigned to pictures, and you want to import your full list into LR, you can Export your keyword list from Bridge (via the flyout menu in the Keywords panel) and Import your list into Lightroom (via the Metadata menu). Or just apply them all to one picture and import that is a pretty quick way too.
Akash
Thanks Akash. However, I don't see where I can set Bridge to write the keywords out to the file. Is that something that happens as I assign them or is it something I do before I export?
Bridge always records keywords with the images. It's automatic - you won't need to do anything when you import the photos into LR.
Do I have to re-import the images?
Because in my situation I do have assigned keywords in Bridge on images already in the library in LR.
So what I would like is that these keywords are also in LR aswel.
Not re-import, but use the command Metadata > Read Metadata.
However, note that this means all metadata. Imagine you have edited pictures in Lightroom but keyworded them in Bridge - Read Metadata will read all metadata from Bridge, overwriting the adjustments done in LR. In future, if you insist on using both apps, you can get around this issue by enabling the automatic writing of metadata in LR (Catalog Settings, Metadata tab).
It's easier for most people to use one program or the other. If you want to use both, you really need to experiment and test. Focus on the commands and settings mentioned above.
