A script which imitates doc.TextSelection property
Jun 23, 2017 Jun 23, 2017
What exactly does doc.TextSelection contain? How can I print its contents? and can anyone provide an example script using which one can essentially perform the equivalent of "selecting" the entire contents of a paragraph to perform some operations on it?
Scripting
472
Mentor , Jun 26, 2017 Jun 26, 2017
Hi varuns44789478,
A TextSelection property uses a TextRange structure, which is an array of two text locations (TextLoc). A TextLoc itself is an array of a paragraph object and an offset. It is a little tricky to understand, but it starts to make sense if you think about it for a while. The TextLoc is like an insertion point in the document, so it can be identified by the parent paragraph and the character offset from the beginning of the paragraph. A selection in a document is effectively a ran
Mentor ,
Hi varuns44789478,
A TextSelection property uses a TextRange structure, which is an array of two text locations (TextLoc). A TextLoc itself is an array of a paragraph object and an offset. It is a little tricky to understand, but it starts to make sense if you think about it for a while. The TextLoc is like an insertion point in the document, so it can be identified by the parent paragraph and the character offset from the beginning of the paragraph. A selection in a document is effectively a range between two text locations, hence the TextRange structure.
Here is basic code that would select an entire paragraph, assuming you already had the paragraph object:
var tr = new TextRange();
tr.beg.obj = tr.end.obj = pgf;
tr.beg.offset = 0;
tr.end.offset = Constants.FV_OBJ_END_OFFSET;
doc.TextSelection = tr;
As far as "printing" a text range, there is no direct way. You have to be creative. Below is a script that I use to print various things related to the current selection in a document or book. Just select something and run it. I hope this helps some.
Russ
function cm_ReportIds(doMsgBox, doConsole)
    var msg = "";
    var doingBook = false;
    var file = app.ActiveDoc;
    if(!file.ObjectValid())
        file = app.ActiveBook;
        doingBook = true;
        alert ("No active document or book.");
        return;
    msg += "----------------------------------------\n";
    if(doingBook)
        msg += "ACTIVE BOOK: ";
    else
        msg += "ACTIVE DOCUMENT: \n\n"
    msg += file.Name + "\n(ID: " + file.id + ")\n";
    msg += "----------------------------------------\n\n";
    msg += "CURRENT ELEMENT SELECTION (er = file.ElementSelection):\n\n";
    var er = file.ElementSelection;
    if(!er.beg.parent.ObjectValid() &&
        !er.beg.child.ObjectValid() &&
        !er.end.parent.ObjectValid() &&
        !er.end.child.ObjectValid())
        msg += "(No valid element selection)\n";
    else
        msg += "er.beg.parent (element):  ";
        if(er.beg.parent.ObjectValid())
            msg += "<" + er.beg.parent.ElementDef.Name + ">      (ID: " + er.beg.parent.id + ")\n";
        else msg += "-NONE-\n";
        msg += "er.beg.child (element):    ";
        if(er.beg.child.ObjectValid())
            msg += "<" + er.beg.child.ElementDef.Name + ">      (ID: " + er.beg.child.id + ")\n";
        msg += "er.beg.offset: " + er.beg.offset + "\n\n";
        msg += "er.end.parent (element):  " ;
        if(er.end.parent.ObjectValid())
            msg += "<" + er.end.parent.ElementDef.Name + ">      (ID: " + er.end.parent.id + ")\n";
        msg += "er.end.child (element):    ";
        if(er.end.child.ObjectValid())
            msg += "<" + er.end.child.ElementDef.Name + ">      (ID: " + er.end.child.id + ")\n";
        msg += "er.end.offset: " + er.end.offset + "\n";
    if(!doingBook)
        msg += "CURRENT TEXT SELECTION (tr = file.TextSelection):\n\n";
        var tr = file.TextSelection;
        if(tr.beg.obj.ObjectValid())
            msg += "tr.beg.obj (pgf ID):  " + tr.beg.obj.id + "\n";
            msg += "tr.beg.obj (pgf format):  " + tr.beg.obj.Name + "\n";
            msg += "tr.beg.offset:  " + tr.beg.offset + "\n\n";
            msg += "tr.end.obj (pgf ID):  " + tr.end.obj.id + "\n";
            msg += "tr.end.obj (pgf format):  " + tr.end.obj.Name + "\n";
            msg += "tr.end.offset:  " + tr.end.offset + "\n";
        else msg += "(No valid text selection)\n";
        msg += "CURRENT GRAPHIC SELECTION:\n\n";
       var graphic = file.FirstSelectedGraphicInDoc;
       var path = "";
        if(graphic.ObjectValid())
            msg += "Selected graphic object: ";
            if(graphic.constructor.name == "AFrame")
                msg += "Anchored frame       (ID: " + graphic.id + ")\n";
                var elem = graphic.Element;
                if(elem.ObjectValid())
                    msg += "Anchored frame element:  <" +
                        elem.ElementDef.Name + ">    (ID: " + elem.id + ")\n";
                msg += "First graphic object in the frame: ";
                graphic = graphic.FirstGraphicInFrame;
                    msg += graphic.constructor.name + "       (ID: " + graphic.id + ")\n";
                    if(graphic.constructor.name == "Inset")
                        path = graphic.InsetFile;
                else msg += "(none detected)";
            else
                msg += "Parent anchored frame: ";
                graphic = graphic.FrameParent;
                if(graphic.ObjectValid() && graphic.constructor.name == "AFrame")
                    msg += "  ID: " + graphic.id + "\n";
            if(path != "")
                msg += "\nReferenced graphic filepath:\n" + path + "\n";
        else msg += "(No valid graphic selection)\n";
    if(doMsgBox)
        alert(msg);
    if(doConsole)
        while(msg.length > 0)
            Err(msg.substring(0, 255));
            msg = msg.substring(255, msg.length);
Hi Russ,
This helps a lot.
Varun
I am not sure exactly what you mean by printing the TextSelection, but here is a function that will retrieve the text so you can do something with it:
var doc = app.ActiveDoc;
// Display the selected text in an alert dialog box.
alert (getText (doc.TextSelection, doc));
function getText (textObj, doc) {
    // Gets the text from the text object.
    var text = "", textItems, i;
    // Get a list of the strings in the text object or text range.
    if (textObj.constructor.name !== "TextRange") {
        textItems = textObj.GetText(Constants.FTI_String);
    } else {
         textItems = doc.GetTextForRange(textObj, Constants.FTI_String);
    // Concatenate the strings.
    for (i = 0; i < textItems.len; i += 1) {
        text += (textItems.sdata);
    return text; // Return the text
By printing the contents I mean being able to print the values of the TextSelection object attributes
