Hi, I use Lightroom 6 successfully, but today when in Library and changing to Develop it said the file could not be found. I updated and rebooted, but now Develop is missing completely! Any suggestions?
Peter
[Here is the list of all Adobe forums... https://forums.adobe.com/welcome]
[Moved from generic Cloud/Setup forum to specific Program forum... Mod]
Only the Develop Heading is missing. See post above to fix that. But hitting the d key (Lower Case D, No Shift) should take you to the develop module whether or not that Heading is displayed or not.
Press D
An entirely different problem, the file (or folder that contains it) has been renamed, moved or deleted outside of Lightroom. On Windows, it could also mean that the drive letter has changed. To fix the problem, please read these instructions: Adobe Lightroom - Find moved or missing files and folders
I feel that I have been misunderstood. The 'Develop' heading at the top of
the Lightroom page has vanished. The problem began when I was in Library
mode, and clicked on Develop to work on an image. I received the message
that the folder could not be found. I tried updating Lightroom, and
rebooted, but now Develop has vanished from the programme.
Peter
(Personal Info removed by Moderator)
As you have explained things, there are two different problems
Does pressing D cause the Develop heading to appear? (it sounds like you haven't even tried)
Does the problem where you get the message that the File cannot be found disappear, or does it still happen?
If I am still misunderstanding, then show us a screen capture of these problems.
Also, don't post your telephone number or address in a public forum like this.
HI,
The Develop part of the programme is missing completely as you can see from
the attached screenshot. When I had the problem with the message file not
found it remained on the screen while I was in the Library mode.
I did not notice that my details had been included as a footer, sorry about
that.
Peter
Thanks Jim,
That worked for me.
Peter
On Sun, Jun 25, 2017 at 8:04 PM, Just Shoot Me <forums_noreply@adobe.com>
Hi Jim,
However, I still have the issue of not being able to transfer from Library
to Develop as you can see from the attached screenshot!
Peter
There is no Attached screen shot. you have to actually log in to the forum site and post the screen shot in your reply. You can not include a screen shot in an Email reply.
Your other problem, "File could not be found", is because you moved or delete the original file or it is on an External drive that is not connected or has problems/faults/failed.
Hi Jim,
Is this better?
Peter
Apparently you have a folder of images that you moved, and you didn't use Lightroom to move the folder. Does that sound like something you did?
Please read the link that I provided in my first reply in this thread. It explains how to fix this problem.
Sorry,
Just right click in the menu area next to Library and make sure there is a checkmark in Develop. As far as your "missing" photos are concerned, check out this article:
https://www.lightroomqueen.com/lightroom-thinks-my-photos-are-missing-how-do-i-%EF%AC%81x-it/
