Lightroom and Photoshop are crushing every other step..
Jun 20, 2017 Jun 20, 2017
I just got new custom build workstation and trying to move my workflow
The problem is that every other step Lightroom and Photoshop applications are crushing -- switching from Library to Developer tab in LR,
Saving file in PS - crushes LR, Working with Nik filters in PS - crushes PS.. and that's just a start.
Everything worked fine on same files/catalogs on old hardware.
I tested setup under Windows 7 and Windows 10 with the same results, so pretty sure it is hardware issue..
Question is -- is there a way to figure out which hardware give me problem?
TIA
884
LEGEND , Jun 20, 2017 Jun 20, 2017
First two troubleshooting steps:
- Try unchecking the option Preferences > Performance > Use Graphics Processor.
- Also, if you have an AMD / ATI graphics chipset, see: Lightroom: Crashing with GPU acceleration on (AMD Radeon driver 17.4.4) | Photoshop Family Customer Community
- Also, if you have an AMD / ATI graphics chipset, see: Lightroom: Crashing with GPU acceleration on (AMD Radeon driver 17.4.4) | Photoshop Family Customer ...
Jun 25, 2017 Jun 25, 2017
Thank you
did both of the steps you mentioned and it seems to resolve the problem
I guess the next step is to get different video card
Your graphics card may be sufficient, at least for LR.  Unless you have a large 4K or 5K display, enabling the graphics processor usually yields little performance benefit (and sometimes slows things down).  Also, an Adobe employee has said in that bug-report thread that AMD was supposed to fix the driver bug in their next release.
Which card do you currently have?
I actually have large 4K display and unchecking everything makes LR running (drawing tabs and refreshing images on screen) pretty slow for me. is there are a date for next driver release?
Thank you
Is there are a date for next driver release?
All we know is that Simon Chen, Adobe Principal Computer Scientist, said last week, "The latest word is that AMD is going to push out a fix in their next driver update."
Which graphics card do you have?
Depending on the card, you've got a couple of workarounds, as described in the previously linked bug report: Lightroom: Crashing with GPU acceleration on (AMD Radeon driver 17.4.4) | Photoshop Family Customer ...
- Change some advanced settings in the AMD Settings utility.
- Roll back to the previous version of the AMD driver (17.4.3): Crash Camera Raw or Lightroom
I have Radeon RX580 -not sure what numbers bellow mean..
Graphics Card Manufacturer - Powered by AMD
Graphics Chipset - Radeon RX 580 Series
Device ID - 67DF
Vendor ID - 1002
SubSystem ID - 0521
SubSystem Vendor ID - 1043
Revision ID - E7
Bus Type - PCI Express 3.0
Current Bus Settings - PCI Express 3.0 x4
BIOS Version - 015.050.002.001
BIOS Part Number - 115-D009PI2-101
BIOS Date - 2017/03/28 02:58
Memory Size - 8192 MB
Memory Type - GDDR5
Memory Clock - 2000 MHz
Core Clock - 1360 MHz
Total Memory Bandwidth - 256 GByte/s
Memory Bit Rate - 8.00 Gbps
2D Driver File Path - /REGISTRY/MACHINE/SYSTEM/ControlSet001/Control/Class/{4d36e968-e325-11ce-bfc1-08002be10318}/0000
Radeon Software 17.6.2
Software versions:
Radeon Settings Version - 2017.0612.1651.28496
Driver Packaging Version - 17.10.3211.1011-170612a-315162E-CrimsonReLive
Provider - Advanced Micro Devices, Inc.
2D Driver Version - 8.1.1.1599
Direct3D® Version - 9.14.10.01261
OpenGL® Version - 6.14.10.13476
OpenCLâ„¢ Version - 22.19.171.257
AMD Mantle Version - 9.1.10.0189
AMD Mantle API Version - 102400
AMD Audio Driver Version - 7.12.0.7724
Vulkanâ„¢ Driver Version - 1.5.0
Vulkanâ„¢ API Version - 1.0.39
I did play with "Vertical Refresh" settings are per link you have me, but that did not help
The RX480 was released last year, and the RX580 is a slightly modified version of that. According to this Adobe Help page, the card should be compatible with LR: Adobe Lightroom GPU Troubleshooting and FAQ
You could try rolling back to driver 17.4.3, which has worked for many people.
should be... that's why we picked it.
I just rolled back the driver to 17.4.3.... and got LR crashing again
Sigh, I guess you'll have to wait for the next AMD driver release.
