I am new to after effects, I try and research some tutorials in google and youtube, but can still find an answer.
There are some transitions pack you can buy in the internet. But I want to make my own transition in after effects and use it as template in premiere pro.
I saw some youtube tutorials where they make differnt transitions, but they inkluded 2 or more video clips in after effects directly.
But I don't want to inklude the video directly in after effects, because the videos should be assets of premiere pro.
In other packages I saw that they use green screens (for simple transitions, but also for complex animations like throwing polariods pictures on a table).
How can I make a transition in after effects more general, so that I have not to inklude the video stuff in after effects.
Do you have some tutorials or keywords under which I can my own reserach?
Many thanks
You can't. That's just how it works. Your comp in AE simply becomes a clip in Premiere and by its nature a clip is a flat stream. Any work to edit such stuff therefore relies on doing it in AE. Of course you can get crazy and build all sorts of templates and mattes and employ every trick in the book to use them in premiere, but why woulkd you? The facts won't change - some st
...Copy link to clipboard
You can't. That's just how it works. Your comp in AE simply becomes a clip in Premiere and by its nature a clip is a flat stream. Any work to edit such stuff therefore relies on doing it in AE. Of course you can get crazy and build all sorts of templates and mattes and employ every trick in the book to use them in premiere, but why woulkd you? The facts won't change - some stuff is simply too complex and requires AE.
Mylenium
Hi Mylenium,
thanks I am understanding what you are meaning.
But how does such greenbox transitions works?
Color Transitions Pack Green Screen - YouTube
I see some templates/animation where pictures can be replaced by using a green box like here:
Creative PowerPoint Timeline with Photos - Cool Animation Tutorial - YouTube
I gues that I make green boxes in after effects, but how do I insert real pictures in premiere pro?
Do I use object tracking in premiere pro?
I do not understand the magic yet 🙂
Many thanks in advance.
None of that stuff will require any keying at all. you simply build it and use AE's ability to generate a proper Alpha transparency, which Premiere will fully use and recognize. Then it's merely a matter of adding a second video track below.
Mylenium
OK thanks for your help. I will try to find some tutorials regarding to your keywords.
Finaly I found a tutorial explaining it very good.
They make also use of color key, matte, luminenc and so on:
Mask and Luma Matte Transitions with After Effects and Premiere Pro Tutorial - YouTube
