Hi, I need to shuffle words in paragraphs. I found the script below but it shuffles paragraphs themselves, I'm not quite savvy enough to modify it myself just yet. Any pointers?
I use InDesign to efficiently plan social media posts for many accounts and repeating hashtags can get you shadowbanned. I have a list of 100~ relevant tags I'd like to randomize and copy/paste selections from.
var mRAND = Math.random,
LOCS = [LocationOptions.AFTER, LocationOptions.BEFORE];
function shuffleSelectedParagraphs()
var s = app.selection && app.selection[0],
ps = s && s.hasOwnProperty('paragraphs') && s.paragraphs,
n = ps && ps.length,
i = n, j, k, d;
if( n < 2 ) throw Error("Please select at least two paragraphs.");
var sto = ps[0].parentStory,
ip0 = ps[0].insertionPoints.firstItem().index,
ip1 = ps[n-1].insertionPoints.lastItem().index,
EOF = ps[n-1].characters.lastItem().contents != '\r';
if( s = s.hasOwnProperty('appliedFont') ) app.selection = [];
if( EOF ) ps[n-1].insertionPoints.lastItem().contents = '\r';
while( i-- )
do{ j = ~~(n*mRAND()) }while( i==j )
k = ~~(2*mRAND());
if( 2*k-1 != j-i ) ps.move(LOCS
,ps ); }
if( EOF ) sto.characters.lastItem().contents = '';
if( !s ) return;
sto.insertionPoints[ip0].select();
sto.insertionPoints[ip1].select(SelectionOptions.ADD_TO);
try{ shuffleSelectedParagraphs() }catch(_){alert(_.message);}
Hi wespor,
To keep more consistent with the original shuffle-paragraph routine—http://forums.adobe.com/message/3834317#3834317—you may also try this:
...function shuffleSelectedWords()
const mRAND = Math.random;
var s = app.properties.selection && app.selection[0],
ws = s && s.hasOwnProperty('words') && s.words,
n = ws && ws.length;
if( n < 2 ) throw Error("Please select at least two words.");
var sto = ws[0].parentStory,
ip0 = ws[0].insertionPoints.first
Not a solution but a reasonable workaround for the current script: put each word in a separate paragraph by changing all spaces to a return. Run the script. Change returns back to spaces.
A somewhat sloppy implementation.
function shufflePargraphWords(paragraph) {
paragraph = app.selection[0];
if (!paragraph || !paragraph.hasOwnProperty('paragraphs')) {
return 'no selection';
paragraph = paragraph.paragraphs[0];
var a, temp, n, words, firstWord, x, level;
paragraph.insertionPoints[-1].contents = ' ';
app.findGrepPreferences = app.changeGrepPreferences = null;
app.findGrepPreferences.findWhat = '\\S+\\s*';
words = paragraph.findGrep().slice();
len = words.length;
while (len) {
x = (Math.random() * len--) | 0;
temp = words[len];
words[len] = words
; words
= temp; }
len = words.length;
n = len - 1;
level = $.level;
$.level = 0;
while (len--) {
try {
words[len].move(LocationOptions.AT_END, paragraph);
} catch (e) {}
$.level = level;
if (paragraph.characters[-1].contents === ' ') {
paragraph.characters[-1].remove();
return 'Shuffled';
app.doScript(shufflePargraphWords, ScriptLanguage.JAVASCRIPT, undefined, UndoModes.ENTIRE_SCRIPT, 'Shuffled Words');
HTH
Trevor
Hi wespor,
ip0 = ws[0].insertionPoints.firstItem().index,
ip1 = ws[n-1].insertionPoints.lastItem().index;
if( s=s.hasOwnProperty('appliedFont') ) app.selection = [];
ws = ws.everyItem().contents;
for( var t ; n ; (t=ws.splice(~~(n--*mRAND()),1)[0]), ws.push(t) );
ws = ws.join(' ');
sto.insertionPoints.itemByRange(ip0,ip1).contents = ws;
if( !s ) return;
sto.insertionPoints[ip0+ws.length].select(SelectionOptions.ADD_TO);
try{ shuffleSelectedWords() }catch(_){ alert(_.message) }
Note. — This code should be a bit faster since it doesn't hit the DOM during the shuffling stage (to the price of losing character style ranges.)
Marc
Thank you, that is awesome! Trying to figure out how to reverse engineer that and sort by Alphabetical order next. I need to shuffle between the two.
