Everytime i do a freaking 3d extrusion my text changes to white and it wont change colors. HELLPPPPP
Can you attach two full screenshots.
The first immediately before the extrusion - include the layers panel with the text layer selected.
The second immediately after the extrusion with the 3D and properties panel included (with the front inflation material selected) as well as the properties panel.
Dave
I dont know how to do a screenshot. I'm using windows. I've tried the print screen thing.
Use the Windows snipping tool (type Snip into the windows search box). Just paste the screenshots straight into the forum post
Dave
From the drawing artifacts alone it is clear that you ahve an issue with your graphics hardware - either the driver isn't up to date, not configured suitably or your graphics hardware is inadequate to begin with. You need to work on that. Providing system info might halep people to advise.
Mylenium
I agree with Mylenium - you have a graphics issue. Your 3D panel and Properties panel look normal but look at the edge of the window where the ruler should be and you are showing parts of another window.
Go to Help - System info press copy and paste the info here.
Also show your Preferences 3D settings and Preferences Performance settings
Dave
Thanks guys! Below is my system info and preferences.
Adobe Photoshop Version: 2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967 x64
Number of Launches: 48
Version: 7 SP1
System architecture: Intel CPU Family:6, Model:5, Stepping:5 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, HyperThreading
Physical processor count: 2
Logical processor count: 4
Processor speed: 2394 MHz
Built-in memory: 5942 MB
Free memory: 2457 MB
Memory available to Photoshop: 5023 MB
Memory used by Photoshop: 70 %
History Thumbnails: Enabled.
Touch Bar: Enabled.
Alias Layers: Disabled.
Modifier Palette: Disabled.
Highbeam: Enabled.
Image tile size: 128K
Image cache levels: 4
Font Preview: Medium
TextComposer: Latin
Display: 1
Display Bounds: top=0, left=0, bottom=900, right=1440
OpenGL Drawing: Enabled.
OpenGL Allow Old GPUs: Not Detected.
OpenGL Drawing Mode: Advanced
OpenGL Allow Normal Mode: True.
OpenGL Allow Advanced Mode: True.
AIFCoreInitialized=1
AIFOGLInitialized=1
OGLContextCreated=1
NumGLGPUs=1
NumNativeGPUs=0
glgpu[0].GLVersion="2.1"
glgpu[0].IsIntegratedGLGPU=1
glgpu[0].GLMemoryMB=2746
glgpu[0].GLName="Intel(R) HD Graphics"
glgpu[0].GLVendor="Intel"
glgpu[0].GLVendorID=32902
glgpu[0].GLDriverVersion="8.15.10.2993"
glgpu[0].GLRectTextureSize=8192
glgpu[0].GLRenderer="Intel(R) HD Graphics"
glgpu[0].GLRendererID=70
glgpu[0].HasGLNPOTSupport=1
glgpu[0].GLDriver="igdumd64.dll,igd10umd64.dll,igdumdx32,igd10umd32"
glgpu[0].GLDriverDate="20130130000000.000000-000"
glgpu[0].CanCompileProgramGLSL=1
glgpu[0].GLFrameBufferOK=1
glgpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="1.20 - Intel Build 8.15.10.2993"
glgpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[1447]
glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[8]
glgpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[16]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[16]
glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[16]
glgpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[512]
glgpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[1024]
glgpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[41]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
glgpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=0
License Type: Subscription
Serial number: 96040476013455956985
GUIDBucket:
bucket: 167
test: ReduceUXFriction
Application folder: C:\Program Files\Adobe\Adobe Photoshop CC 2017\
Temporary file path: C:\Users\Tatiana\AppData\Local\Temp\
Photoshop scratch has async I/O enabled
Scratch volume(s):
Startup, 114.7G, 59.2G free
Required Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\Plug-ins\
Primary Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\
Installed components:
A3DLIBS.dll A3DLIB Dynamic Link Library 9.2.0.112
ACE.dll ACE 2017/01/26-01:10:02 79.579975 79.579975
AdbePM.dll PatchMatch 2016/11/03:19:48:57 1.578146 1.578146
AdobeLinguistic.dll Adobe Linguisitc Library 10.0.0
AdobeOwl.dll Adobe Owl 5.2.11
AdobePDFL.dll PDFL 2016/08/10-16:53:20 79.195992 79.195992
AdobePIP.dll Adobe Product Improvement Program 7.4.1.60.45263
AdobeSVGAGM.dll AdobeSVGAGM 79.579975 79.579975
AdobeXMP.dll Adobe XMP Core 2016/09/14-01:09:01 79.159824 79.159824
AdobeXMPFiles.dll Adobe XMP Files 2016/09/14-01:09:01 79.159824 79.159824
AdobeXMPScript.dll Adobe XMP Script 2016/09/14-01:09:01 79.159824 79.159824
adobe_caps.dll Adobe CAPS 10,0,0,6
AGM.dll AGM 2017/01/26-01:10:02 79.579975 79.579975
ahclient.dll AdobeHelp Dynamic Link Library 2.2.0.1
AIDE.dll AIDE 2016/05/27-01:08:49 79.574279 79.574279
amtlib.dll AMTLib (64 Bit) 10.0.0.119 BuildVersion: 10.0; BuildDate: Thu Dec 22 2016 3:0:7) 1.000000
ARE.dll ARE 2017/01/26-01:10:02 79.579975 79.579975
AXE8SharedExpat.dll AXE8SharedExpat 2015/03/13-23:40:54 79.562390 79.562390
AXEDOMCore.dll AXEDOMCore 2015/03/13-23:40:54 79.562390 79.562390
Bib.dll BIB 2017/01/26-01:10:02 79.579975 79.579975
BIBUtils.dll BIBUtils 2017/01/26-01:10:02 79.579975 79.579975
boost_date_time.dll photoshopdva 10.0.0
boost_signals.dll photoshopdva 10.0.0
boost_system.dll photoshopdva 10.0.0
boost_threads.dll photoshopdva 10.0.0
cg.dll NVIDIA Cg Runtime 3.0.00007
cgGL.dll NVIDIA Cg Runtime 3.0.00007
CITThreading.dll Adobe CITThreading 2.1.0.1 2.1.0.1
CoolType.dll CoolType 2017/01/26-01:10:02 79.579975 79.579975
dnssd.dll Bonjour 3,0,0,2
dvaaudiodevice.dll photoshopdva 10.0.0
dvacore.dll photoshopdva 10.0.0
dvacrashhandler.dll Adobe Audition CC 2017 10.0.0
dvamarshal.dll photoshopdva 10.0.0
dvamediatypes.dll photoshopdva 10.0.0
dvametadata.dll photoshopdva 10.0.0
dvametadataapi.dll photoshopdva 10.0.0
dvametadataui.dll photoshopdva 10.0.0
dvaplayer.dll photoshopdva 10.0.0
dvatransport.dll photoshopdva 10.0.0
dvaui.dll photoshopdva 10.0.0
dvaunittesting.dll photoshopdva 10.0.0
dynamiclink.dll photoshopdva 10.0.0
ExtendScript.dll ExtendScript 2016/12/13-13:10:33 80.1089815 80.1089815
icucnv40.dll International Components for Unicode 2014/10/31-16:52:45 Build gtlib_6.0.21339
icudt40.dll International Components for Unicode 2014/10/31-16:52:45 Build gtlib_6.0.21339
icuuc40.dll International Components for Unicode 2014/10/31-16:52:45 Build gtlib_6.0.21339
igestep30.dll IGES Reader 9.3.0.113
imslib.dll IMSLib DLL 10.0.0.11
JP2KLib.dll JP2KLib 2017/04/05-14:24:38 79.266006 79.266006
libifcoremd.dll Intel(r) Visual Fortran Compiler 10.0 (Update A)
libiomp5md.dll Intel(R) OpenMP* Runtime Library 5.0
libmmd.dll Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler 12.0
LogSession.dll LogSession 7.4.1.60.45263
mediacoreif.dll photoshopdva 10.0.0
MPS.dll MPS 2016/09/14-15:20:26 79.577269 79.577269
pdfsettings.dll Adobe PDFSettings 1.04
Photoshop.dll Adobe Photoshop CC 2017 18.1.1
Plugin.dll Adobe Photoshop CC 2017 18.1.1
PlugPlugExternalObject.dll Adobe(R) CEP PlugPlugExternalObject Standard Dll (64 bit) 7.0.0
PlugPlugOwl.dll Adobe(R) CSXS PlugPlugOwl Standard Dll (64 bit) 7.0.0.67
PSArt.dll Adobe Photoshop CC 2017 18.1.1
PSViews.dll Adobe Photoshop CC 2017 18.1.1
SCCore.dll ScCore 2016/12/13-13:10:33 80.1089815 80.1089815
SVGRE.dll SVGRE 79.579975 79.579975
svml_dispmd.dll Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler 12.0
tbb.dll Intel(R) Threading Building Blocks for Windows 4, 4, 2016, 0412
tbbmalloc.dll Intel(R) Threading Building Blocks for Windows 4, 4, 2016, 0412
TfFontMgr.dll FontMgr 9.3.0.113
TfKernel.dll Kernel 9.3.0.113
TFKGEOM.dll Kernel Geom 9.3.0.113
TFUGEOM.dll Adobe, UGeom© 9.3.0.113
updaternotifications.dll Adobe Updater Notifications Library 10.0.0.1 (BuildVersion: 1.0; BuildDate: BUILDDATETIME) 10.0.0.1
VulcanControl.dll Vulcan Application Control Library 5.3.0.16
VulcanMessage5.dll Vulcan Message Library 5.3.0.16
WRServices.dll WRServices Thu Jan 07 2016 04:50:10 Build 0.21960 0.21960
wu3d.dll U3D Writer 9.3.0.113
Required plug-ins:
3D Studio 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D”
Accented Edges 18.1.1 - from the file “Filter Gallery”
Adaptive Wide Angle 18.1.1 - from the file “Adaptive Wide Angle”
Angled Strokes 18.1.1 - from the file “Filter Gallery”
Average 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Average”
Bas Relief 18.1.1 - from the file “Filter Gallery”
BMP 18.1.1 - from the file “Standard MultiPlugin”
Camera Raw 9.10.1 - from the file “Camera Raw”
Camera Raw Filter 9.10.1 - from the file “Camera Raw”
Chalk && Charcoal 18.1.1 - from the file “Filter Gallery”
Chrome 18.1.1 - from the file “Filter Gallery”
Cineon 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Cineon”
Clouds 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Clouds”
Collada 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D”
Color Halftone 18.1.1 - from the file “Standard MultiPlugin”
Colored Pencil 18.1.1 - from the file “Filter Gallery”
CompuServe GIF 18.1.1 - from the file “Standard MultiPlugin”
Conté Crayon 18.1.1 - from the file “Filter Gallery”
Craquelure 18.1.1 - from the file “Filter Gallery”
Crop and Straighten Photos 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “CropPhotosAuto”
Crop and Straighten Photos Filter 18.1.1 - from the file “Standard MultiPlugin”
Crosshatch 18.1.1 - from the file “Filter Gallery”
Crystallize 18.1.1 - from the file “Standard MultiPlugin”
Cutout 18.1.1 - from the file “Filter Gallery”
Dark Strokes 18.1.1 - from the file “Filter Gallery”
De-Interlace 18.1.1 - from the file “Standard MultiPlugin”
Dicom 18.1.1 - from the file “Dicom”
Difference Clouds 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Clouds”
Diffuse Glow 18.1.1 - from the file “Filter Gallery”
Displace 18.1.1 - from the file “Standard MultiPlugin”
Dry Brush 18.1.1 - from the file “Filter Gallery”
Eazel Acquire 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “EazelAcquire”
Entropy 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics”
Export Color Lookup Tables 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Export3DLUT”
Extrude 18.1.1 - from the file “Standard MultiPlugin”
FastCore Routines 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “FastCore”
Fibers 18.1.1 - from the file “Standard MultiPlugin”
Film Grain 18.1.1 - from the file “Filter Gallery”
Filter Gallery 18.1.1 - from the file “Filter Gallery”
Flash 3D 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D”
Fresco 18.1.1 - from the file “Filter Gallery”
Glass 18.1.1 - from the file “Filter Gallery”
Glowing Edges 18.1.1 - from the file “Filter Gallery”
Google Earth 4 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D”
Graphic Pen 18.1.1 - from the file “Filter Gallery”
Halftone Pattern 18.1.1 - from the file “Filter Gallery”
HDRMergeUI 18.1.1 - from the file “HDRMergeUI”
HSB/HSL 18.1.1 - from the file “Standard MultiPlugin”
IFF Format 18.1.1 - from the file “Standard MultiPlugin”
IGES 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D”
Ink Outlines 18.1.1 - from the file “Filter Gallery”
JPEG 2000 18.1.1 - from the file “JPEG2000”
Kurtosis 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics”
Lens Blur 18.1.1 - from the file “Lens Blur”
Lens Correction 18.1.1 - from the file “Lens Correction”
Lens Flare 18.1.1 - from the file “Standard MultiPlugin”
Liquify 18.1.1 - from the file “Liquify”
Matlab Operation 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “ChannelPort”
Maximum 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics”
Mean 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics”
Measurement Core 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “MeasurementCore.8me”
Median 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics”
Mezzotint 18.1.1 - from the file “Standard MultiPlugin”
Minimum 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics”
MMXCore Routines 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “MMXCore”
Mosaic Tiles 18.1.1 - from the file “Filter Gallery”
Multiprocessor Support 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “MultiProcessor Support”
Neon Glow 18.1.1 - from the file “Filter Gallery”
Note Paper 18.1.1 - from the file “Filter Gallery”
NTSC Colors 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “NTSC Colors”
Ocean Ripple 18.1.1 - from the file “Filter Gallery”
OpenEXR 18.1.1 - from the file “Standard MultiPlugin”
Paint Daubs 18.1.1 - from the file “Filter Gallery”
Palette Knife 18.1.1 - from the file “Filter Gallery”
Patchwork 18.1.1 - from the file “Filter Gallery”
Paths to Illustrator 18.1.1 - from the file “Standard MultiPlugin”
PCX 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “PCX”
Photocopy 18.1.1 - from the file “Filter Gallery”
Photoshop 3D Engine 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Photoshop3DEngine”
Photoshop Touch 14.0 - from the file “PSDX”
Picture Package Filter 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “ChannelPort”
Pinch 18.1.1 - from the file “Standard MultiPlugin”
Pixar 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Pixar”
Plaster 18.1.1 - from the file “Filter Gallery”
Plastic Wrap 18.1.1 - from the file “Filter Gallery”
PLY 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D”
PNG 18.1.1 - from the file “Standard MultiPlugin”
Pointillize 18.1.1 - from the file “Standard MultiPlugin”
Polar Coordinates 18.1.1 - from the file “Standard MultiPlugin”
Portable Bit Map 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “PBM”
Poster Edges 18.1.1 - from the file “Filter Gallery”
PRC 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D”
Radial Blur 18.1.1 - from the file “Standard MultiPlugin”
Radiance 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Radiance”
Range 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics”
Render Color Lookup Grid 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Export3DLUT”
Reticulation 18.1.1 - from the file “Filter Gallery”
Ripple 18.1.1 - from the file “Standard MultiPlugin”
Rough Pastels 18.1.1 - from the file “Filter Gallery”
Save for Web 18.1.1 - from the file “Save for Web”
ScriptingSupport 18.1.1 - from the file “ScriptingSupport”
Shake Reduction 18.1.1 - from the file “Shake Reduction”
Shear 18.1.1 - from the file “Standard MultiPlugin”
Skewness 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics”
Smart Blur 18.1.1 - from the file “Standard MultiPlugin”
Smudge Stick 18.1.1 - from the file “Filter Gallery”
Solarize 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Solarize”
Spaces 18.1.1 - from the file “Spaces”
Spatter 18.1.1 - from the file “Filter Gallery”
Spherize 18.1.1 - from the file “Standard MultiPlugin”
Sponge 18.1.1 - from the file “Filter Gallery”
Sprayed Strokes 18.1.1 - from the file “Filter Gallery”
Stained Glass 18.1.1 - from the file “Filter Gallery”
Stamp 18.1.1 - from the file “Filter Gallery”
Standard Deviation 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics”
STL 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D”
Sumi-e 18.1.1 - from the file “Filter Gallery”
Summation 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics”
Targa 18.1.1 - from the file “Standard MultiPlugin”
Texturizer 18.1.1 - from the file “Filter Gallery”
Tiles 18.1.1 - from the file “Standard MultiPlugin”
Torn Edges 18.1.1 - from the file “Filter Gallery”
Twirl 18.1.1 - from the file “Standard MultiPlugin”
U3D 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D”
Underpainting 18.1.1 - from the file “Filter Gallery”
Vanishing Point 18.1.1 - from the file “VanishingPoint”
Variance 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics”
Virtual Reality Modeling Language | VRML 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D”
Water Paper 18.1.1 - from the file “Filter Gallery”
Watercolor 18.1.1 - from the file “Filter Gallery”
Wave 18.1.1 - from the file “Standard MultiPlugin”
Wavefront|OBJ 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D”
WIA Support 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “WIASupport”
Wind 18.1.1 - from the file “Standard MultiPlugin”
Wireless Bitmap 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “WBMP”
ZigZag 18.1.1 - from the file “Standard MultiPlugin”
Optional and third party plug-ins: NONE
Duplicate and Disabled plug-ins: NONE
Plug-ins that failed to load: NONE
Extensions:
com.adobe.inapp.purchase 2.10.56 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CC_LIBRARIES_PANEL_EXTENSION_2_10_56\purchase.html”
New Document 2.0.0 - from the file “C:\Users\Tatiana\AppData\Roaming\Adobe\CEP\extensions\CCX_CMDN_EXTENSION_2_0_0_003\fnft.html”
Libraries 2.10.56 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CC_LIBRARIES_PANEL_EXTENSION_2_10_56\index.html”
com.adobe.experimentation.extension 2.0.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.experimentation.extension\index.html”
Start 2.0.0 - from the file “C:\Users\Tatiana\AppData\Roaming\Adobe\CEP\extensions\CCX_START_EXTENSION_2_0_0_042\index.html”
Adobe Color Themes 6.1.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.KulerPanel.html\index.html”
Export As 3.0.8 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.photoshop.crema\PSPanel\dialog.html”
Device Preview 1.3.2 - from the file “C:\Program Files\Common Files\Adobe\CEP\extensions\com.adobe.previewHD\PSPanel\panel.html”
com.adobe.preview.loader 1.3.2 - from the file “C:\Program Files\Common Files\Adobe\CEP\extensions\com.adobe.previewHD\PSLoader\loader.html”
Installed TWAIN devices: NONE
Hi
I can't see anything wrong with your settings but your intel graphics driver looks old (judging by the date). It will be worth checking for a more recent update (use the Intel site rather than rely on Windows update)
Dave
I've updated the graphics driver and the 3d text still turns out white.
As Trevor pointed out to you earlier, your graphics card is at the very bottom of the barrel in terms of features and speed. To be blunt, integrated Intel HD graphics chips are quite unsuitable for 3d work, and Photoshop's older 3d implementation isn't going to help here either.
You seem to be out of luck.
does that mean i'd just have to get a better labtop?
Yes, you definitely need a computer with a better graphics card and more RAM. Then you should be able to get your 3d text working fine. 🙂
Well, I've seen Photoshop 3d working on similar system hardware. Have you tried changing to a lower level hardware support when you click on the "Advanced Settings" button, and restarted Photoshop?
Also try creating 3d text in a low-resolution document, for example 800x600, and see if that works.
And check if Blender will work - if that works, than the driver functions. Btw, you could also create the 3d text you need in Blender, and import the 3d model in Photoshop. Also test if you are able to import a simple 3d model in Photoshop, and check if that displays properly.
The screenshot in post 4 points to a GPU issue. There are issues with the ruler on screen. So it is not just a 3D rendering issue.
The starting point should be a GPU driver update. Then as rayek.elfin points out, try each GPU setting.
Dave
Like Dave says, you should check that your system has the most up to date driver. I'm guessing that your system is fairly old as it does not say what version of Intel HD graphics you have, and that yours is the original. But if it will take one of these _much_ more recent drivers, then go right ahead (a little bit of irony there ) and up date it.
The bottom line here is that your system spec is marginal. You have just 8Gb RAM, and built in graphics taking some of that. Your issue with 3D looks _very_ much like it is GPU related, and I suspect that an up to date driver is your only chance... but don't hold your breath.
Good luck. I say that a lot, but this time you are going to need it.
It might be worth you taking this Lynda.com course by Nigel French, it shows you how to produce all kinds of Photoshop type effects, including 3D (you can get a 30-day free trial): Photoshop for Designers: Type Effects
One of my favourite Lynda presenters, and one of my very favourite Linda titles. I love that he never ever says, 'I'm gonna go right ahead', unlike so many Lynda presenters that start ever sentence that way. Nigel is a nice person as well,and happy to respond to emails if you have a thorny Type issue you can't get to grips with (having obviously tried this forum first of course ).
Hi Trevor,
I've emailed Nigel with a copy of your kind comments.
Being English he's unlikely to say "I'm gonna go right ahead" !
Cheers,
Derek
