Tried doing a search for this and couldn't find anything, though I'm sure it's possible. Can someone help me out please? I'm not super familiar with target or adobe analytics so if it requires linking a4t and exporting from analytics I'd like to have some resource for that as well.
Solved! Go to Solution.
Total Likes
Hi Csanderson99,
Based on your case study I assume that you have following scanario
Hope my answer helps
Manish Agravat
Total Likes
Hi Csanderson99,
I would check target API documentation given at below link
https://www.adobe.io/apis/marketingcloud/target/docs/reference/delivery.html
From My understanding A4T works before your test.
and your reporting happens in analytics if that's already done in your case then you can check adobe analytics API documentation to pull data from analytics that you can find from below url.
https://marketing.adobe.com/developer/documentation/analytics-reporting-1-4/get-started
I hope this helps
Manish Agravat
Total Likes
Hi Csanderson99,
Can you please share the use-case you are trying to achieve so that we can further help you with your query.
We are not able to fully understand your query.
Regards
Parit Mittal
Total Likes
Hi Parit,
Sure. The use case is that I want to have a better calculation of RPV than what I can get from a t-test. To do that I need to run a export on all user level data with each corresponding revenue amount. Once I get the user level data I can run a Mann Whitney U Test. But to do that I'd need literally every user revenue value, individually for each variant.
Total Likes
Total Likes
Hi Csanderson99,
Manish Agravat
Total Likes
