I'm working on a project that should render as many videos as possible. Only 3 images in the project change after every render. The output length is 12 seconds and it takes about 90 seconds to render the video.
After Effects is running on a Windows 10 device with 64gb ram, a GTX 1060 videocard, a i7 processor and a Samsung 960 EVO 500GB SSD.
When rendering a video the CPU usage goes to 100% and memory stays on <5%
Are there ways to speed up this small renders even more?
It's not worth the effort to try. A 90-second render for a 12-second video is REALLY good!
When ever you render videos in AE, On the Caps key which fasten up the rendering by not updating the screen preview...but i am doubtful if it will make any difference which such a short duration render.
Hi thijn,
Are you still facing this problem? If not, let us know how you solved it. If so, please let us know so we can assist you further.
Kevin
