Problem with page size (letter 8x11 inches)
Jun 27, 2017 Jun 27, 2017
Hi. Recently, I discovered that the default page size for letter when you select "New --> Document Type: U.S.Paper  --> Size: Letter",   puts a value of 8 in the width field (8 inches instead of 8,5). I think this have to be a problem with the colon/dot. ¿How can I change the value without adding a custom size?
I use Photoshop 2017.1.1   20170425.r.252 x64 (english)  on Windows 7 (spanish)
3.7K
Community Expert , Jun 27, 2017 Jun 27, 2017
The defaults are here  (Windows)
C: Program Files > Adobe > Adobe Photoshop CC2017 > Required Default New Doc Sizes.json
If you decide to edit the file then do so at your own risk and make a copy first !
Dave
Adobe
Hi
It is working correctly here on both the legacy and the "new" New Document dialogues. That is with Photoshop 2017.1.1 r.252 (English) on Windows 10 (English).
Have you tried resetting preferences ?
Dave
Thanks. I just did the preferences reset, but the problem persists. In the "new" new document the name of the preset says "Letter 8 x 11 in @ 300 ppi"  and "Legal 8 x 14 in @ 300 ppi". This must be 8,5, right?
Here is what I see :
Dave
This is my screen. I think it's a problem with the dot. I can't put 8.5 in the field, I must put 8,5 (with colon). I was trying to edit the file for the preset. In the presets folder there are files for this, with a .IMZ extension, but is not a script.
Those IMZ files are different . They are the "Fit to " presets in the Image Size dialogue.
I'm still searching for the location of the New File presets (if they are indeed stored as presets and are not hard coded)
Dave
That's correct. 8.5 inches.  8,5 International or UK might be an alternate.
With the New File dialog open, press the ALT key and the Cancel button changes to Reset. Click on Delete to see if it restores US Letter.
If not, proceed with the Custom Size and save it as US Letter.
Hi. The Alt- reset did not fix the issue.  I will have to use custom size while the adobe team fix this. ¿How can I report this bug?
Photoshop Family Customer Community  is where problems can be reported to Adobe Staff.
Dave
Hi.  Changing the dot to colon  (8.5 to 8,5) solved the issue, in Letter and Legal sizes. Thanks for the help.
Must be an issue between the English Photoshop and the Spanish Windows. Glad it is sorted for you though.
Dave
Advisor ,
Yes it used be 8.5 in x 11 in @ 300 psi . If you can share the screen shot would help to understand the issue better.
Because i am using photoshop cc 2017.1.1 r252 on MAC and it works fine.
Vishu Aggarwal
Adobe Certified Instructor, Professional and Expert
